Finishing a build and need a long distance great radio setup for my big mono? Any suggestions?? Not a fan of spektrum and tactic seems to be hit or miss with distance. My Traxxas Rx/Tx from my Spartan worked real well. Suggestions?
What's the best long distance radio??
Many would say Futaba.My private off road rc track
Why is distance so critical...you won't be able to tell if its coming or going .Grand River Marine Modellers
Flysky GT3B tested to 2 miles, not sure you'd need much more than that.
Buy a futaba. I have tactic, spektrum, and futaba radios and I would rate them 1. Futaba (never loses signal as long as you keep it dry) 2. Tactic (rarely loses signal) 3. Spektrum (regularly loses signal) others may have different opinions but I wouldn't have a flysky as I have witnessed 2 major crashes over the receivers failing
Futaba 3PM. You can a used one for a reasonable price on ebay. Despite some saying you do not need an antenna outside the boat, mount one anyway for maximum range. I'm with devo that the Futaba recievers can glitch if they get wet. Nothing a shot of wd40 and burst of air won't immediately cure.Mike Chirillo
www.capitolrcmodelboats.com
Let me elaborate on the Futaba wet reciever glitching. Then only time I ever had a problem with my Futaba FASST radio is when the boat flooded and I didnt take time to ensure the reciever was dry before the next run.
If you want maximum range, the line of sight between the transmitter and receiver must be unobstructed. Anything less and your rolling the dice.Mike Chirillo
