FLYSKY GT3B --- help please
  • ksm2001
    • Jun 2007
    • 397
    Also make sure the fail safe is programed proper for neutral throttle position. I don't have the instructions with me but if I recall its not programed for that until you set it up.
    • Alexgar
      • Aug 2009
      • 3701
      http://www.hobbyking.com/hobbyking/s...o_System_.html
      go to the files tab Dana and you can download pdf file
      • Alexgar
        • Aug 2009
        • 3701
        the failsafe is programmed to WOT i lost an elam that way
        • dana
          • Mar 2010
          • 3660
          thanks
          • dana
            • Mar 2010
            • 3660
            are you saying it comes pre set to wot? that means i have to reprogram yes?
            • dana
              • Mar 2010
              • 3660
              if i want to bind to a certain channel, do i have to set the channel on the tx, then shut it off, so when i turn on to bind its binding to the correct channel?
              • properchopper
                rcgoatbuild@snotmail.com
                • 7708
                Originally posted by dana View Post
                Thanks guys! One more question.... Is it necessary to run the antenna outside the hull?
                I run 8 boats on my GT3b ; about a year now with no probs. Internal antennas on all. Simple/quick mount - foam block cross drilled, some tubing, stick down & done (pictured is the HK Rx; added some to a recent order-same Rx)
                • Alexgar
                  • Aug 2009
                  • 3701
                  run great but as i found out got to close to a dock and she went wide oper into the dock and did major damage i repaired it but ate about 80$ due to the repair when i let her go so reprogram the failsafe
                  another link page 24
                  • dana
                    • Mar 2010
                    • 3660
                    Thanks you guys! Most helpful -)
                    Binding went fine with all 3 rx. I got tx and 3rx for 53 shipped. And it's a nice radio! Love hobbypartZ...
                    So my throttle channels are set for reverse but where do you guys keep the throttle trim? On my tactics, it's all the way up. Thanks again
                    • properchopper
                      • 7708
                      Dana, I've found that it's a good practice to set the trim to "zero", then hold trigger on full, plug in battery and let speedy read the full-forward position. That way you'll be assured that you're getting the full forward output of the speedy.
                      BTW yesterday I had a nice in-person conversation with two execs at HobbyPartz- Expect to see more FE support from them in the future if my plan(s) go forward
                      • dana
                        • Mar 2010
                        • 3660
                        Nice Tony! I have had excellent experiences with them. Very happy =)
