Also make sure the fail safe is programed proper for neutral throttle position. I don't have the instructions with me but if I recall its not programed for that until you set it up.
FLYSKY GT3B --- help please
http://www.hobbyking.com/hobbyking/s...o_System_.html
go to the files tab Dana and you can download pdf file
I run 8 boats on my GT3b ; about a year now with no probs. Internal antennas on all. Simple/quick mount - foam block cross drilled, some tubing, stick down & done (pictured is the HK Rx; added some to a recent order-same Rx)Originally posted by dana View PostThanks guys! One more question.... Is it necessary to run the antenna outside the hull?
DSC03174.JPG2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
run great but as i found out got to close to a dock and she went wide oper into the dock and did major damage i repaired it but ate about 80$ due to the repair when i let her go so reprogram the failsafe
another link page 24
Thanks you guys! Most helpful -)
Binding went fine with all 3 rx. I got tx and 3rx for 53 shipped. And it's a nice radio! Love hobbypartZ...
So my throttle channels are set for reverse but where do you guys keep the throttle trim? On my tactics, it's all the way up. Thanks again
Dana, I've found that it's a good practice to set the trim to "zero", then hold trigger on full, plug in battery and let speedy read the full-forward position. That way you'll be assured that you're getting the full forward output of the speedy.Originally posted by dana View PostThanks you guys! Most helpful -)
BTW yesterday I had a nice in-person conversation with two execs at HobbyPartz- Expect to see more FE support from them in the future if my plan(s) go forward
