Brushless motor winding class
This is a sticky topic.
    Nice job. Did you make that cooling jacket?
    • T.S.Davis
      • 6266
      #197
      No. That's an OSE.
      Noisy person
      • RayR
        @SiestaKey.calm
        • 1591
        #198
        Don,
        When complete and fully stuffed with wire, how much does the the motor weigh? 300 grams?
        Thanks,
        Ray
        • HTVboats
          • Jun 2011
          • 936
          #199
          Ray,
          I have a Lep 3660 rewound by Don and it gained 16 grams over the posted stock weight. 251 to 267.
          Mic
          Mic Halbrehder
          IMPBA 8656
          NAMBA 1414
          • donhuff
            • Dec 2014
            • 561
            #200
            Originally posted by jaike5 View Post
            That is correct Don mind you there is a lot to be said for a fine transom !!
            Jay.
            Transom.......... I like that
            AmpDaddy
            don huff
            • donhuff
              • Dec 2014
              • 561
              #201
              Hmmm. 3041 kv. That's a bit much.
              [ATTACH=CONFIG]169558[/ATTACH]
              I like that tach Terry. I bet by being a lazar, it can be used indoors with the lights on.
              AmpDaddy
              don huff
              • donhuff
                • Dec 2014
                • 561
                #202
                Which motor are you talking about Ray?
                If it's the 2000, it doesn't gain much because the slots in the stator are so small that you can't add but a couple of strands of wire. But with the AQ motors, they gain a lot because the slots are huge, and they come with so little wire in them to begin with.
                Like Mic sez above, his Leopard gained several grams. Part of that is due to it being a 2 and a half wind, to begin with. That leaves a lot of empty space in half of the slots. I picked a kv that was close to the original, but was not a half wind, and that fills the slots better.
                AmpDaddy
                don huff
                • donhuff
                  • Dec 2014
                  • 561
                  #203
                  Terry, yeah 3041 is to high to be useful.
                  You know, like I have said several times! You can do a test wind with a single strand of the cat5 26 ga wire, and the motor will run just the same as it does with a full load of wire. That way you can check kv and not spend a lot of time doing it, and don't loose a bunch of your good wire. But with only a single strand of wire, you can't strain it or run it for very long. Plenty long enough to check it out, just watch for a little smoke from the insulation melting.
                  Also, you don't have to go through the trouble of soldering on the connectors. Just twist the wires together, and I have and esc with alligator clips on it that makes it super easy to use.
                  AmpDaddy
                  don huff
                  • donhuff
                    • Dec 2014
                    • 561
                    #204
                    Are ya'll getting the whole "the length of wire determines the KV" thing?
                    And mostly how reducing the length of the wire by 50%, will raise the kv by at least 50%.
                    This isn't exact by any means, but it gives you a rough estimate of where your kv will be going.
                    using the chart above. Look at say a 2D and a 4D. That would be a 50% reduction in the wire length per phase. Now see how the kv went down just a tad more than 50%!
                    Take an 8D and subtract 200% from the wire to a 2D. The kv difference is 280% so you see it aint perfect, but it does give you an idea of where your headed.
                    Man that picture is tiny. Sorry
                    AmpDaddy
                    don huff
                    • T.S.Davis
                      • 6266
                      #205
                      I've looked at those Tp charts a 100 times.
                      That 2D I did was about practicing winding too. I was much quicker this time and didn't screw it up. I suppose I can wind with just a single strand of magnet wire too.
                      3000kv might make a nice 3s motor. Or maybe a straight down straight back boat. Not sure I'll keep it that way. Kind of a waste of rotor and stator as is.
                      I have another 3D to do but after that I'll look into a wye wind fer the learn'n. What's a useful turn to try Don? I'll try it without the bundles the first run through. Need to get some cat5. I'm sure there's one in the house here somewhere. HA Xbox? Diss cO nect.
                      Noisy person
                      • jaike5
                        • 564
                        #206
                        Oh jeez!! Better do that surgery while Tyler is at work!!
                        • donhuff
                          • Dec 2014
                          • 561
                          #207
                          Terry, I too have looked at those charts a lot of times. Just don't look at them say for a 3630 which is the size for P-ltd, and think that you can use their turn count for your motors. Cause it takes a 10D to get 1950 kv in the TP. That would make an AQ have a kv of like 700. It's different for each motor brand.
                          You already have one useless high kv dynamite, I wouldn't think that you need two!
                          If you wind a dyna 2000 at 2Y, it has a kv around 1500.
                          Yes you can use the winding wire for a test wind. It's just a lot easier to do it with the cat5 and be able to strip the insulation with your finger nail. If you do use motor wire, I suggest that you get a 1 lb spool of a bigger size like 23 or 20 ga. Easier to work with and will carry a lot more amps than a single strand of 27 ga.
                          AmpDaddy
                          don huff
                          • T.S.Davis
                            • 6266
                            #208
                            They really did nail it with the Dynamite 2000kv motor. Really is a sweet spot for our application.
                            Maybe I'll put the 3000 in Pete's new sport hydro, wrap the motor in a welding blanket, and let er rip. Got that little boat figured out now.
                            Noisy person
                            • T.S.Davis
                              • 6266
                              #209
                              Noisy person
                              • donhuff
                                • Dec 2014
                                • 561
                                #210
                                Man it's nice to finally see someone trying this stuff, thanks Terry.
                                Yes I like the way they look in colors! Finally got some cat wire I see. Makes it easy doesn't it. You can get that wire at home depot by the foot with 4-6 pairs in it really cheep.
                                Testing a 2 delta again? And I see that you did it the dynamite 2000 way. To satisfy me and to show it to you, try doing it with a normal 2D type wind. You can use the same wirea and it should be about the same length. And the kv should come out within 50-100 of each other.
                                Ready to tackle a Y yet? it's not hard to do with the cat wire.
                                AmpDaddy
                                don huff
