Brushless motor winding class
This is a sticky topic.
    Originally posted by donhuff View Post
    Jay,
    The leads are all the same length for the three legs. They just go around one set of coils twice, and the other set once. 5.5 turns would be 5 turns on one set and 4 on the other. At least that the best that I can figure it out from dissecting a few motors. BUT like on an 1800 AQ motor. The Y connection is in the front of the motor instead of the rear. That means that some of the wire bundle goes through one slot on one side of a coil twice, but only once on the other side of that same coil. Draw a picture of it entering from the bottom, around twice, and then out the top. See there are 3 passes on one side of the coil and only two on the other side. Almost all of the small spec car racing motors are wound that way. Because of the way they are made, this works out good for them.
    Terry we talked about leaving a turn off once before. I tried it but forgot to report about it. I "test" wound a dyna 2000 at 4D and checked the kv, then took one turn off of the last set of coils. Thats easy to do with the cat5 wire. Then retested the kv and it was 150 rpm faster! I should have took a coil off of a second set of coils to see if it upped another 150, but I thought of that to late.
    Whoa, I didn't know it was a Y wind!! I've been setting timing all wrong.
    Never thought that they would put the joint in the front. So, is the 2030 gold can is Y or D now, I forget?? I think it's a Y with joint at back.
    Jay, are you actually doing this? If so are you buying wire from the south or up here?
      Alright blood just shot out of one of me ears? Is that normal?
      Me too...
      • TRUCKPULL
        • 3293
        #183
        UL1 2030 - 2Y
        Larry
        • donhuff
          • Dec 2014
          • 561
          #184
          re read that and see if it makes more sense now. I had a few numbers wrong..
          Remember, your winding coils, three with the same 4' piece of wire,or one coil by it's self with a 4' piece of wire, times 3 per leg
          AmpDaddy
          don huff
          • donhuff
            • Dec 2014
            • 561
            #185
            Larry's right. the 2030 is a 2Y.
            And i think that the 1800 would be called a 2.5Y. But I'm not positive on that one.
            Larry, DD DDDDDD. What's all that about?? I thought that you were a butt man like me
            AmpDaddy
            don huff
            • donhuff
              • Dec 2014
              • 561
              #186
              There's that danged TIMING THING AGAIN!!! Did the 1800 burn up at 15* timing.............NO
              Forget all that BS about timing for D vs Y . Set them all at the same thing and forget about it, PLEASE!
              AmpDaddy
              don huff
              • TRUCKPULL
                • 3293
                #187
                Don - NOT Me - I am still with you!
                I think that was Jay.
                Larry
                • donhuff
                  • Dec 2014
                  • 561
                  #188
                  OOPS, sorry Larry your right again!
                  so Jay is the B O O B guy....
                  AmpDaddy
                  don huff
                  • jaike5
                    • 564
                    #189
                    Ray…. check the thread , I tapped out a few pages back with the lye thing . I have learned a ton of correct information on motors and other stuff from Don. Thanks Don. Ray I'm running a 2014/3 on the wild thing I built 1500kv.
                    J
                    • TRUCKPULL
                      • 3293
                      #190
                      Jay is that a 2014 - 10 -50/3
                      Or is it a 2014 - 15 - 60/3
                      Larry
                        Oh yeah...
                          I've only partially burnt one 1800 and the others are still fine. Years ago in London Ontario I smoked 2 2030's and 2 esc's in one day.
                          • jaike5
                            • 564
                            #193
                            Larry, that would be 2014-15-60/3.
                            J.
                            • jaike5
                              • 564
                              #194
                              That is correct Don mind you there is a lot to be said for a fine transom !!
                              Jay.
                              • T.S.Davis
                                • 6266
                                #195
                                Hmmm. 3041 kv. That's a bit much.
                                Noisy person
