Hobbywing quickrun combo
  • RCTrailblazr
    • Jul 2015
    • 4
    Hobbywing quickrun combo:
    QuicRun-10BL60-SENSORED ESC+QUICRUN-3650-21.5T-SENSORED Motor Combo For 1/10 & 1/12
    This affordable 56g ESC & 21.5 Turn 1760KV 4 pole brushless motor from Hobbywing is a great hop-up for any crawler rig. Hobbywing has really stepped up there game with this combo set. The ESC is equipped to automatically identify sensored or sensorless brushless motors with a proportionate 4 step brake adjustment system and one button quick set feature. This ESC is tough enough for the most advanced crawling and treacherous terrain out there. The set is known to be generally waterproof and also contains a built in BEC that can handle NIMH or 2-3sLipos which is Suitable for any 1/10 & 1:12 On-road/Off-road/F1/Drift vehicle.
    This easy to maintain efficient combo set has heat resistant wires, top branded bearings and components which should be number one on your must have list.
    Link:
    https://www.asiatees.com/display?Mis...al=3236373138?
    Quick Specs:
    Cont./Peak Current/Resistance
    60A/380A/0,0008Ohm
    Motor supports
    Sensored/Sensorless Brushless motor
    Shaft Diamater (mm):3.17
    Shaft Length (mm): 15
    Rotor Pole: 2
    Resist:0.0895?
    No-load Current(Amp):1.0
    Max. Output Power(W):95
    Current at the Point of M.O.P (Amp):28
    YouTube:
    Instagram:
    Facebook:
    Terry Mcgee is on Facebook. Join Facebook to connect with Terry Mcgee and others you may know. Facebook gives people the power to share and makes the world more open and connected.
  • RCTrailblazr
    • Jul 2015
    • 4
    Photos of the combo!
    [ATTACH=CONFIG]139234[/ATTACH][ATTACH=CONFIG]139235[/ATTACH][ATTACH=CONFIG]139236[/ATTACH][ATTACH=CONFIG]139237[/ATTACH]
    Link:
    Quick Specs:
    60A/380A/0,0008Ohm
    Motor supports
    Rotor Pole: 2
    Resist:0.0895?
    YouTube:
    Instagram:
    Facebook:
    https://www.facebook.com/terry.mcgee.501
      Is there any other reason for posting this other than advertising??
