Hobbywing quickrun combo:
QuicRun-10BL60-SENSORED ESC+QUICRUN-3650-21.5T-SENSORED Motor Combo For 1/10 & 1/12
This affordable 56g ESC & 21.5 Turn 1760KV 4 pole brushless motor from Hobbywing is a great hop-up for any crawler rig. Hobbywing has really stepped up there game with this combo set. The ESC is equipped to automatically identify sensored or sensorless brushless motors with a proportionate 4 step brake adjustment system and one button quick set feature. This ESC is tough enough for the most advanced crawling and treacherous terrain out there. The set is known to be generally waterproof and also contains a built in BEC that can handle NIMH or 2-3sLipos which is Suitable for any 1/10 & 1:12 On-road/Off-road/F1/Drift vehicle.
This easy to maintain efficient combo set has heat resistant wires, top branded bearings and components which should be number one on your must have list.
Link:
https://www.asiatees.com/display?Mis...al=3236373138?
Quick Specs:
Cont./Peak Current/Resistance
60A/380A/0,0008Ohm
Motor supports
Sensored/Sensorless Brushless motor
Shaft Diamater (mm):3.17
Shaft Length (mm): 15
Rotor Pole: 2
Resist:0.0895?
No-load Current(Amp):1.0
Max. Output Power(W):95
Current at the Point of M.O.P (Amp):28
YouTube:
Instagram:
Facebook:
Link:
Quick Specs:
60A/380A/0,0008Ohm
Motor supports
Rotor Pole: 2
Resist:0.0895?
YouTube:
Instagram:
Facebook:
