amp to watts on motor
  • jjrctech
    • Feb 2011
    • 187
    if you runing say 6s 22.2v on 1577kv neu 1521 3500w max
    what would be the amp draw??
    at 22.2v , 25.9v and 33v??
    Thanks
    --> 54" fountain - Bonzi boat. http://www.youtube.com/watch?v=_cxR6yDRJXw
  • Make-a-Wake
    FE Rules!
    • 6057
    Not enough info...............a HUGE prop would be alot of amp draw...........tiny prop low amp draw................etc............
    • jjrctech
      • Feb 2011
      • 187
      is there a online a online calculator where it would tell me , I would like to play with numbers, I am think about run 5017/3 ???
      • Chilli
        • 3204
        There are just too many variables. Hull type, size, prop, setup.
        Give us your whole set up and someone here will give you a pretty good estimate.
        Mike Chirillo
        www.capitolrcmodelboats.com
        • lohring
          • Jun 2011
          • 200
          The allowable current would be 158 amps, that is 3500 divided by 22.2. The actual current depends on the things mentioned above.
          Lohring Miller
          • jjrctech
            • Feb 2011
            • 187
            Lohring Miller
            so would a 180a T ESC be good for this ?? setup at 6s 1521 1577kv??? Prop 5017/3?? 44"cat c5000??
            • video200
              • 840
              that motor is to small for a 44" cat.
              that prop is to much for that motor in almost any boat and would most likely melt a 180 within minutes.
              just my $ 0.2
              • Steven Vaccaro
                Administrator
                • 8932
                just my $ 0.2
                agreed.
                Steven Vaccaro
                • jjrctech
                  • Feb 2011
                  • 187
                  agreed.
                  Really 2 x Neu 1521 1577 would be to small for a 44" Mystic ??? what would be better??
                    You need to re-think your goals here. A single 1521 is not enough motor for a 44" cat, and 6S is on the bottom end of acceptable power as well. The two 1527/1Y motors you were selling would be great in that hull as a twin setup. A club member used them in a HPR build and that boat performed very well. Finding the right props was his biggest problem.
                    - What do you expect the cat to do, sport run, race, SAW?
                    - What speed and run time are acceptable to you?
                    - What is your budget for this project?
                    - Do you already have the cat hull?
                    Don't try to re-invent the wheel here. Get proven setups from folks who have ACTUALLY built and run large boats - not recommendations from those who think they know what might work. Follow the wrong advice and you'll end up spending a lot of money and not have a reliable boat.
                    • jjrctech
                      • Feb 2011
                      • 187
                      I was think the 2 x Neu 1527 1250kv would be to strong for this boat IMG_0042.jpg I already have the boat. this is my 2 build, first one was a 54" FOUNTAIN ( http://www.youtube.com/watch?v=_cxR6yDRJXw )which run in the low 60mph , so i wanted to get this one in the 80mph recommend setup wise???
                      • jjrctech
                        • Feb 2011
                        • 187
                        I was try to copy mike76 setup mhz mystic C5000 JBS racing 44,8''
                        2x leopard 4082 2200 kv
                        2x esc 180A turningy + cap bank
                        2x 6S 5800 turningy
                        2x propshop 5017/3
                        he show 84mph
                        I was thinking the 2x Neu 1521 1577kv would be about the same or better then the leopard 4082 2200 kv ???
                          You didn't state this was a twin build in time for my post - several of us assumed you were using a single motor. Two 1521s will work as long as you are careful in the build and don't run too wet. The 1577 Kv motors on 6S will give you good speed, start with props like the K57s and expect high-60s with a good setup (strut/CG). K63s cut to 52-55 mm diameter should up the speed into the high 70s or more. Once you get close you can get metal props, the carbon fiber props will last long enough to get in the ballpark. Watch those Turnigy packs with Neus, those motors will pull more amps than the Leopards will and IME the "C" ratings seem inflated.
                          • jjrctech
                            • Feb 2011
                            • 187
                            [QUOTE=Fluid;339359]You didn't state this was a twin build in time for my post - several of us assumed you were using a single motor. Two 1521s will work as long as you are careful in the build and don't run too wet. The 1577 Kv motors on 6S will give you good speed, start with props like the K57s and expect high-60s with a good setup (strut/CG). K63s cut to 52-55 mm diameter should up the speed into the high 70s or more. Once you get close you can get metal props, the carbon fiber props will last long enough to get in the ballpark. Watch those Turnigy packs with Neus, those motors will pull more amps than the Leopards will and IME the "C" ratings seem inflated.
                            Do you think the 2 x neu 1527 1250Kv would make the boat faster even with that motor weight alot more?? and would be a better pick becuase i already have them??
                            I would run the neu 1527 on a Swordfish 240hv ESC with hyperion battery
                              The problem is that the 15271/1Y motors do not have enough Kv to reach 80 mph. You'd need props with about 4" of pitch to go that fast, or you'd want to run on 8S. The 1527/1.5D would be better from a Kv standpoint. Don't worry about a few extra ounces of weight in a boat that size with that much power.
