Seaking 180 ESC RPM Question?
  • Howard
    • 269
    I was wondering if anyone has experienced this before. I had a 60 amp esc in my boat running 3S lipos. My dry RPM using my tach at WOT was about 35,000 RPM. Now that I have the 180 seaking installed it runs about 45,000 RPMs with only 2S lipos. Yes it screams at wide open throttle. The throttle works fine. Em I crazy or what???? I have not tested in the water yet.
    Howard
  • Howard
    • 269
    PS, I'm using a 2600KV motor. Is it possible the motor is bad? I smoked the 60amp esc. Thus the new 180 esc.
      First off, never run a BL motor at full throttle without a load - nothing good will happen if you do. The rpm you see is pretty meaningless, what matters is rpm on the water. So don't be crazy test WOT in the water only!
      • detox
        • 2357
        Tach is probably wrong using 2s
        • Boaterguy
          • 1779
          unless the 3S is wimping out at WOT, probably not but you never know.
          specs on the batts?
          • drwayne
            • 3012
            3S (12.6) 2600kv ~33krpm ..... so 35k is about it for a foolish wot on dry land with inaccuracies of tachs
            2S (8.4) 2600kv ~21krpm ~! 45krpm not possible... was tach configured wrong ?..
            What tach ?
            aero blade counting tachs just tell lies on small diam props with large blades for eg.
            W
            What type of tach.. a prop blade counter ? Was it set to count one blade..
            • Boaterguy
              • 1779
              21.8k is what you should be getting (approx)
              that's about half of what your tach is giving so I think dr wayne hit it on the head.
              • Howard
                • 269
                Globee intellitach definitely set on 2 blades. I've done this many times before with no adverse affects on the boat/motor. Of course I don't run it long maybe 20 to 30 seconds tops. I can tell just by the sound that the motor is screaming. It's really wierd and it makes no sense I know but I guess I'll have to see what it does in the water. Batteries are 2S 5000 mah 40c.
                Howard
                • Howard
                  • 269
                  prop is a balanced, polished octura x435. Like I said it makes no sense I know but this is what it is doing
                  • drwayne
                    • 3012
                    what brand motor here ?
                    2 pole or 4 ?
                    20-30 seconds is a nightmare long time wot unloaded.
                    It's the unsensored wot and the unharnessed wind down to idle that's bad.. all that backemf with nowhere to go...very bad for esc/motor... is that what caused your stock 60A to go
                    If you like your electronics. dont repeat that
                    lightbulb moment
                    you run 2S2P and have them wired wrong = 4S1P @2600 = 43krpm ??
                    • Howard
                      • 269
                      Great Planes Ammo 36-56-2600 In-Runner Brushless Motor No the first esc went while on the water running 4s 4000 40c bat. Nothing is wired wrong, I've been doing this for years and this is the first time this is happening I'll run this in the water today and see what happens
                      • drwayne
                        • 3012
                        Great motor.
                        Ive it's bigger sister in a 6ft aero
                        Eagle tree make a good rpm counter applet for under 100 complete .. leave onboard and grab loaded rpm.. good for prop choises too.
                        Not common, nor impossible, for an esc to misread pole positions in can at high rpm and misfire... prompting rotor lock or rotor flash ( spins higher )
                        best of luck !
                        W
                        • Howard
                          • 269
                          OK Doctor, I know you think I'm nuts (that's OK ) but for your diagnosis I made a video. Hope you can help...
                          I'm only using 2S 5000 40c ...everything is wired correctly. As I mentioned the motor is screaming. Although I did this for a very short time it is definitely hitting the 50,000 rpm range without a doubt.
                          • drwayne
                            • 3012
                            mark the trailing edge of your prop blades with a solid black line and try again.
                            W
                            • drwayne
                              • 3012
                              if the motor is a 2pole, and those esc fire for a 4 pole, the motor will rev twice as fast as kv suggests.
                              Dont know the time where you are, but its 11pm here Sat night, and Im to work at 0600 Sunday.
                              time for me to Zzzzzzzzzzzzz.
                              will log on in 18hrs
                              W
