ESC QUESTION, Hifei Swordfish PLUS 200 amp
  • Mecka1990
    • Aug 2012
    • 180
    i got a traxxas XO-1 and will take the receiver and transmitter to test it on the esc´s, there is definetly something wrong, 6 months im searching for a reason why this crap wont work, everythign done what is in my possibility, maybe tomorrow it works ;(
    Zonda 41" Carbon Cat, Motors: 2x 2075KV 3674 Brushless Inrunner, ESC: 2x 200Ish plus, Props: 2x 42mm, 2x 5s 5000Mah 50/100c
    • Mecka1990
      • Aug 2012
      • 180
      with the last drve of my zonda i get only 34 km/h, lvc was off, 39mm props on 2075 lv dwind sss 37mm motors with 5s, thats really not ok ;(
      • Mecka1990
        • Aug 2012
        • 180
        so, i tryd today 3 different transmitters, 1,5 hours working on this and i cant set the esc´s for 100% throttle, i tryd everything that is possible, still not solved, i writed a mail to hifei, lets see what they say to this.
        • drwayne
          • 3012
          When you use USB it will show the throttle range setting. if this is more than 700us it is 100%....
          China has Chinese New Year holidays now.. every one is closed until maybe 20th !
          This is most strange
          1. does your Rx use power from esc ? I would try outside Rx battery ( use USB to turn of Rx power from esc )
          I hear the esc play tone for 4 cells in video #1
          You have set by USB to 4cell ?
          Set by USB the timing for medium.
          very unusual for 2x esc same fault..
          cheers
          W
          • Mecka1990
            • Aug 2012
            • 180
            ah thats right, i will try to connect the esc´s with usb again
            • Mecka1990
              • Aug 2012
              • 180
              Only 512 throttle range, what now?
              • drwayne
                • 3012
                2am here.
                Let me sleep !
                Maybe I dream of answer haha
                • Mecka1990
                  • Aug 2012
                  • 180
                  HAHAHA, yesterday i writed and workd on the boat from 22 pm till 7 am, and yes i was here and writed everything good night, hahaha, i hope you find a answer :p
                  • Mecka1990
                    • Aug 2012
                    • 180
                    drwayne, got a screenshot for you.
                    you can show me yours? or someone others can show me that he really get 100% throttle?
                    • Mecka1990
                      • Aug 2012
                      • 180
                      and this one is the second esc:
                      whats now wrong? -.-
                      • Mecka1990
                        • Aug 2012
                        • 180
                        i tryd now the traxxas TQI and the second both ESC got the same Parameters like before, nothing changed...
                        • drwayne
                          • 3012
                          here is SF200 on 4S.
                          I think your problem is somehow Tx/Rx.
                          • Mecka1990
                            • Aug 2012
                            • 180
                            what exactly you mean with Tx/Rx?
                            • Mecka1990
                              • Aug 2012
                              • 180
                              SOLVED, i get it, finally, i needet to set my spektrum DX2.0 on 75% throttle, then i Setted up the Esc: 3 beeps when plugin in with holding Throttle Max forward, then comes 1 beep, pause, 2. beep, pause, 3. beep (release).
                              after that, i give full throttle to record the data for the data logger, with about 20% throttle i change on the transmitter from 75% to 125%, and then i get the 100% throttle.
                              oh man, that was a hard job, about 3 months working on this -.- (not all the time, every week 2-3 times)
                              screen 1 = Esc on the Right side
                              screen 2 = Esc on the left side
                              how you can see the motors are working a little bit different, shoud i see that when driving in water?
