ESC QUESTION, Hifei Swordfish PLUS 200 amp
  • Mecka1990
    • Aug 2012
    • 180
    Hi,
    someone got the listed ESC like me and can give me a detailed information?
    when i give full throttle, what color and how the esc flashs? mine blinks green every 0,5 seconds with full throttle, i think i read somewhere that it must be red and constant with full throttle, is that right?
    Zonda 41" Carbon Cat, Motors: 2x 2075KV 3674 Brushless Inrunner, ESC: 2x 200Ish plus, Props: 2x 42mm, 2x 5s 5000Mah 50/100c
  • drwayne
    • 3012
    solid green
    turn the throttle adjust on transmitter to 120% and try again.
    some 2.4ghx Tx do not calibrate SF esc properly...
    DocW
    • Mecka1990
      • Aug 2012
      • 180
      solid green
      DocW
      i tryd, still flashing green every 0,5 seconds, set my spektrum to 125% throttle, tryd to calibrate the throttle endpoints new, esc new calibrated, still the same, hmmmm
      • drwayne
        • 3012
        on spektrum, set throttle to 100%
        Calibrate esc again with this Tx setting.
        -- turn on Tx.
        -- hold throttle 100%
        -- turn on esc.
        -- "music" dling dling dling dling .. pause beep beep ..pause.. beep beep .. pause ... beep beep ...
        -- somewhere in middle of 2 beeps ( pause ) you release throttle back to zero
        now adjust Spektrum throttle to 125%
        try again.
        DocW
        • Mecka1990
          • Aug 2012
          • 180
          -- turn on Tx.
          -- turn on esc.
          try again.
          DocW
          thats what i have done, hmmmmm
          maybe the esc dont get enough power? 37mm 2075kv dwind, twinsetup with 5s 80c 4000 mah
          • Mecka1990
            • Aug 2012
            • 180
            latest firmware for ish 200+ amp i get from hifei.com via skype, before 3 days, so the firmware isnt the problem
            • Mecka1990
              • Aug 2012
              • 180
              -- turn on Tx.
              -- turn on esc.
              try again.
              DocW
              got a vid for you, help me getting this stuff runnign corectly haha, i have no idea what to do. just uploading...
              • Mecka1990
                • Aug 2012
                • 180
                so, here it is, on the first vid you can see i hold the throttle on the transmitter on 100%, connecting the esc with lipo, no 2 beeps with pauses between, hahaha, whats next?
                i tryd: spektrum 100% th settings, set esc with the first 4 beeps, not solid green with full throttle (as you can see), set throttle 125%, still not solid green, but a little bit more power.
                1. vid esc settings with weird sounds:
                2. Spektrum dx20 125% throttle:
                im getting frustrated
                • Mecka1990
                  • Aug 2012
                  • 180
                  and yes i set the esc´s first with 100% spektrum throttle settings and after setting them i change to 125%, i tried 125% first to and then tested, not working.
                  lipos are fully charged for the tests.
                  still same esc settings like lvs, startup, and the rest
                  • Mecka1990
                    • Aug 2012
                    • 180
                    as you can see on the first vid the leds are only flashing with full throttle
                    when setting up the esc´s i tried to realese the throttle after the first period of beeps and this funny sound, but when i do so it starts again, i tried to realese, press, realese, bla bla, when i realese it with the 5. beep, it starts 5x beep, funny sound, and again beeps till 10.
                    • drwayne
                      • 3012
                      in video #1
                      you need to release throttle at 0.19 or 0.20 or 0.21 !
                      there is one beep ... beep ... beep ... beep !
                      not 2 .. have not heard this routine before, but means same.,
                      W
                      • Mecka1990
                        • Aug 2012
                        • 180
                        thats what i did, hmmmmm, any other ideas?
                        • Mecka1990
                          • Aug 2012
                          • 180
                          i try today the traxxas transmiter when i get home, this poo must works -.-
                          • drwayne
                            • 3012
                            what usb setting for this esc ?
                            • Mecka1990
                              • Aug 2012
                              • 180
                              lvc: 5cells (tryd already 2 cells lvc, maybe lvc was on, wasnt)
                              Startup: standart (tryd soft and fast, fast startup is not good because he jumps from 20% throttle instantly to over 60% and he is screaming, dont want my boat try to fly)
                              pwm rate: 8 khz (tryd 12 and 16)
                              timing: auto
                              Cutoff Voltage/Cell: 3.1
                              Brake Types: no brakes
                              Cutoff Type: Hard Cutoff
