MGM esc programming problem
This is a sticky topic.
  • StevenBryant
    • Nov 2012
    • 366
    #31
    Doug check the threads that I started, there is one I put up when I had an issue with a 1527 1500kv and an mgm28026 controller, there should be a video of what happened. I would do it for you but I’m struggling to do it on my mobile phone
    • RandyatBBY
      • 3944
      #32
      I plan on testing the YEP 180HV and a Kosmik 200HV with cooling for potential HV controllers in my boats in 2018.
      I have tried a set of YEP 180HV on a twin and will never use them again.
      Randy
      BBY Racing
        #33
        This one?
        https://forums.offshoreelectrics.com...527&highlight=
        • RaceMechaniX
          • 3024
          #34
          Care to elaborate Randy? What motors did you run? I would prefer to save a nice hull from a smelly mess if I can avoid it.
          I use ducted fans as load dyno's for testing combinations. The smaller one is a Schueleber DS-86-HDS ducted fan mounted on some plywood. Allows me to load the motor at decent RPM's for extended periods to see if controllers have any issues. I ran the YEP and a 2250 for 4 and a half minutes at about 75% and everything was only warm. DC amp draw was around 125A.
          The larger one is a 160mm I think and uses a Lehner 30 series motor which provides plenty of load not to mention tornado level wind speeds in my shop.
          Tyler Garrard
          NAMBA 639/IMPBA 20525
          T-Hydro @ 142.94mph former WR
          • rayzerdesigns
            • Dec 2013
            • 1228
            #35
            So just to theorize.. I put a 280 on my limited mono today.. it didn’t cut off.. but when I pulled the data said it was pulling 395 amps.. come on!!
            • RaceMechaniX
              • 3024
              #36
              That's phase current, not DC current. It's also the peak value of the AC wave form I believe. So 395Apeak =279Arms.
              What was the DC current?
              Tyler Garrard
              • StevenBryant
                • Nov 2012
                • 366
                #37
                Yes fluid that is correct.
                • RandyatBBY
                  • 3944
                  #38
                  [ATTACH=CONFIG]155499[/ATTACH][ATTACH=CONFIG]155500[/ATTACH][ATTACH=CONFIG]155501[/ATTACH]
                  Hear is the thread of the build. I still have the ESC. they look fine. Actually I was drawn to them becuse of the size of the fets. they look a lot like a Schultz I had big hopes for the Yep 180.
                  https://forums.offshoreelectrics.com...Central+marine
                  Randy
                  BBY Racing
                  • RandyatBBY
                    • 3944
                    #39
                    So how to you work the math when you read the phase current top get dc current? I am spiking 900 amps some times with my 4S setups and it was hard for me to belive. That setup is a Neu 1530 .5Y, MGM 400-63, 4S3P 3300maH cells 65C/130C, ABC 1814, 11 pound 34 inch sport hydro. This hydro runs around 67MPH to 70MPH. I onlu have problem on the launch getting up to speed once it is at full speed it is OK from there on.
                    This is the boat. I have ran the same esc in this boat for going on three seasons. The only better ESC IMO is the 40.160
                    Randy
                    BBY Racing
                    • RandyatBBY
                      • 3944
                      #40
                      I have forgotten the Yep were 120 not 180 I just read that.
                      Randy
                      BBY Racing
                      • Doug Smock
                        • 5359
                        #41
                        Hey fellas, Tomas is getting registered so he can post.
                        MODEL BOAT RACER
                        IMPBA President
                        IMPBA 19887L CD
                        NAMBA 1169
                        • photohoward1
                          • 1781
                          #42
                          Randy. I am running a Dual 300 Flyer in a Twin Cat. Plett Motors. The Big 370BM/40/A1/S..X457 props. All good so far.
                          • RandyatBBY
                            • 3944
                            #43
                            Thanks Howard I do not get around much any more. I have great memories of racing you years ago. I am glad I went to every race I ever did. (good and bad) I am not familiar with the Plett brushless motor do you have any comparison pictures?
                            It is good to hear about the Filer ESC, I have seen them work and then stop . I have never owned one.
                            Randy
                            BBY Racing
                            • triton
                              • Jun 2015
                              • 48
                              #44
                              I was running too with a singe 300A Flyer. It was good until 12s. Then the capacitors leads burned.But that was a bit overloaded.....
                              But before we burned 5-6 pcs. 250-400A Flyer. The Flyer contact Cathy very helpful and she provided me some spare parts free for repair.
                              • photohoward1
                                • 1781
                                #45
                                10s Motor. Ran these in our 1/8 scales.
