MGM esc programming problem
This is a sticky topic.
  • Doug Smock
    • 5359
    Several guys in the local club reported seeing something similar with their HV MGM controllers. Throttle drops off after a short time, logging shows excessive amps even with proven setups, etc. These guys are not newbies. That’s all I know at the moment, odd.
    One of our club members is having the same experience. Unfortunately he had a bunch of coin invested in them before he realized they are paperweights. IIRC two of them went back to the manufacturer and were returned with the same issues.
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    • RaceMechaniX
      • 3024
      It is known that there are good motor and ESC combinations and you have found one of the bad ones.
      The MGM 25063, 40063 and even the 80063 do not work well with 4-pole Delta wind motors. In particular the Neu, TP and similar motors.
      The same controllers work very well with the LMT motors and some 4-pole Wye wind motors.
      The same is true for the newer Schulzes, they work well with LMT motors, but not the 4-pole Delta wind motors. The old Schulzes have no issue.
      I demagnetized a Neu 2215/1.5Y with a 40063 in about 30 seconds due to incorrect settings. A fridge magnet had more strength than the rotor when i pulled it out.
      since that incident, I only run the larger format MGM's (25063 and 40063) with LMT's. The smaller body 25035 and 28026 seem to work better with the non-LMT motors.
      I will say the MGM's have many protection features that prevent them from burning up which is usually a plus, however all the watchdog features also limit performance unexpectantly sometimes.
      Tyler
      Tyler Garrard
      NAMBA 639/IMPBA 20525
      T-Hydro @ 142.94mph former WR
        This came from the controller databox. This is the peak current. The input current much lower.
        I dont know how. The motor 1188kv.
        This is another known issue, see post #6. Excessive logged amps, which could be related to the low power issue.
        “Known” by who Tyler? This is the first I’ve heard of it, ditto at least some others. The few guys I know who own them now find they have invested thousands of dollars in equipment they can’t use. Next they have to buy new motors just to run their MGMs?
        I know none of this is your fault, but it is very frustrating for the consumer.
        • triton
          • Jun 2015
          • 48
          Tyler
          Agree with you
          No doubt that these are good solutions to protect the controllers but when I was purchased the controllers nobody said from MGM Peter pay attention how you chose your motor.........
          But we exchanged many e-mails about the technical details with Martin and Tomas from MGM.
          Is there any experience with y wind tp motor?
          • robw
            • May 2014
            • 58
            just bought a tp5870 "D" wind/mgm 400 (to go in a buggy) hope it works
            • photohoward1
              • 1781
              My Schulze 40-160 controllers shut down after about 1 lap of full throttle runs on my TP d wind Motors. As I always tell guys in my club. Some combos just don’t play well together.
              • RaceMechaniX
                • 3024
                There were no specific posts, but several sidebar discussions on compatibility issues in the past. I know I have posted several times about Neu/TP motors with MGM controllers. And to anyone that has asked my advice I usually steer them away from these combo's. I agree it is frustrating to the end customer, but in defense of the ESC companies it takes hundreds of hours to tune ESC characteristics to suit such a wide variety of motors. Think about how many pole number, wind configurations, connectors, cable lengths and other permutations .
                We were very fortunate that some like the Castle can be easily set-up for a wide variety of motors.
                @ Triton, I have likely had all the same conversations you have had with Martin and MGM. My hope was that they would work on the tuning and get it solved over time.
                I have worked with MGM on professional level controllers and know they are smart and capable guys. They have also built a very safe controller compared to 90% of the market. I don't know how well they will work with a Wye wind TP. Probably better, but I believe it has more to due with the inductance in the motors than the Winds.
                Try setting your timing to 5 Deg, and low start-up torque or acceleration.
                @Howard, you are talking about the new ones right? Your old ones should be pretty strong.
                -Tyler
                Tyler Garrard
                • Doug Smock
                  • 5359
                  It would be good if MGM would find a solution for guys like Don that are out to the tune of almost 2K! IMO they should have put a warning / disclaimer out there knowing there can be an issue.
                  Sure hope Castle comes back to the party!
                  MODEL BOAT RACER
                  IMPBA President
                  IMPBA 19887L CD
                  NAMBA 1169
                  • RandyatBBY
                    • 3944
                    My set up work well with a 40.160 but I am afraid of the getting it wet problem. I guess I could conformal coat it every 6 months and that will solve the problem.
                    Randy
                    BBY Racing
                    • StevenBryant
                      • Nov 2012
                      • 366
                      Tyler I have a 24.150wk that I was lan to use with a castle 1512 1y motor, do you think I may have problems with this combination?
                      • photohoward1
                        • 1781
                        -Tyler
                        Newer.. yes
                        • triton
                          • Jun 2015
                          • 48
                          I have some new information, but I think you know it.
                          MGM controllers work well with Lehners.
                          I found a 2250/10 motor in my cabinet, and today I have done some test run. Bigger prop size like with the other type motor and with blocked hull the MGM works great.
                          The acceleration time 0,5! Quick full throttle and the 2250 pushed out 9200w!!!!!!!!!!!!
                          There was no blocking.
                          Solution:must to buy lehners:)
                          • T.S.Davis
                            • 6266
                            Frustrating. I'm in for 4 of these too.
                            It's not just the HV controllers. I raced a setup on a Seaking 180 that burned an MGM 280.26 to a crisp. MGM was able to extract the data off of the remains. It was pulling 1100 amps according to the log. But it works on a 180? hmmmm
                            I'm down to one that works but the link to PC doesn't work so no adjusting the 35 or so settings or data logging. I was able to set the Q record with that one though. On D wind no less. Picture me shrugging my shoulders.
                            Noisy person
                            • RaceMechaniX
                              • 3024
                              @ Steven, The 24.150 is probably the only Schulze that has a true rating equal to what is on the nameplate. If you can keep it below 150A DC input you will be OK. However, the 24.150's do not perform above the nameplate specs like the 40.160 and 32.200. The 40.3XX is another story.
                              @ Peter, good to hear the boat runs good with the Lehner. Unfortunately, there are no real good marine ESC's for the 4-pole motors. I plan on testing the YEP 180HV and a Kosmik 200HV with cooling for potential HV controllers in my boats in 2018.
                              My new style 40.160wk's and 32.200wk's will run quite happily with Wye wind 4-pole motors when I stick with a reasonable current.
                              The first gen Seaking 180's were pretty strong and surprised many of us. Mark F ran a T180 with some crazy Delta wind Neu motor when he went 80+ in his SAW mono. I thought for sure it was going to blow, but it survived. I have pushed one hard myself and it still runs great.
                              @ Terry, oddly enough I have burned up every other controller model except the MGM's. They have always current limited before I could cook them.
                              Tyler Garrard
                              • Doug Smock
                                • 5359
                                I contacted MGM through their Facebook page. Tomas is going to check this thread out tomorrow.
                                I searched for the other thread that was up recently but was unable to find it. Does anyone know where it was?
                                MODEL BOAT RACER
                                IMPBA President
                                IMPBA 19887L CD
                                NAMBA 1169
