Turnigy 120 esc only runs for 30 secs
  • haggis
    • Aug 2011
    • 59
    My turnigy 120 ESC only works for around 30 secs then cuts out
    after that it barely turns the motor over for about 5 secs then cuts out again
    does this with my overlander motor and a brand new turnigy on 3s
    any ideas?
    www.redbayboats.com
  • Boaterguy
    • 1779
    could be an LVC problem
    try charging the pack (i'f you're running it out of the box)
    if not, perhaps disable the LVC but be careful about runtime so you don't overdischarge your packs
    • carlcisneros
      • Jan 2010
      • 1237
      also, if you are running like 20C packs, switch over to at least 40C packs.
      • Boaterguy
        • 1779
        what he said.
        the lower C rating packs (lower discharge) will dip in voltage under load, thus triggering the LVC.
        + they will puff up and/or worse if you draw too much from them.
