Spektrum radio / Hydra 120 compatible ?
  • cacofonix
    • Jul 2008
    • 243
    #46
    ok folks, i found problem !!!
    i recalibrate esc after changing radio EPA to 80% ...just to check
    and ....no change
    BUT !!! , since the beginning, i made all tests by unplugging motor after calibration
    and this time , i try full throttle WITH motor plugged .........
    and and and : LED IS FULL ....... unbelievable, esc behaviour is not same with or without motor plugged.
    herve
    • nutz1207
      • Jul 2009
      • 19
      #47
      wow, maybe that is the problem for me to, i will check this when i get home. im just a little uneasy about going full throttle with the motor pluged in.
      • nutz1207
        • Jul 2009
        • 19
        #48
        well that was it. recalabrated esc, left motor plugged in and tried full throttle and had solid red led. im with you cacofonix it doesn't make any sense that the motor would have to be plugged in. but it worked. but i thought that i read a post from joe that you should unplug the motor when you check for full throttle. maybe thats just for saftey.
        also want to say thanks to everybody for there help. its nice to now that people are here to help when you need it.
        Dustin
        • cacofonix
          • Jul 2008
          • 243
          #49
          yesssssssss good to find help and help others
          problem leaving motor plugged is just noise !!
          when doing my test yesterday, all familly went in workshop to understand what was making such noise !!!!
          herve
          • cacofonix
            • Jul 2008
            • 243
            #50
            hi
            to be complete on this subject, this morning i redo all but after upgrading ESC to 1.04 version
            same behaviour
            blinking without motor
            full with motor
            if joe has an explanation to give ....
            herve
