you mean in esc menu ?
Spektrum radio / Hydra 120 compatible ?
yes there is an end point adjustment and a travel adjust both effect the throttle.
It has been a while since I programmed my DX2 but I think there are two functions that could alter the throttle
Jim"Our society strives to avoid any possibility of offending anyone except God.
Billy Graham
You guys with the set up problems should contact HappyOne
He is using the same radio now with Castle ESC and I saw him reprograming, calibrating his CC ESC with no problem, ask him please.
RobertDJI Drone Advanced Pilot
Canada
I have been using a DX3S radio system in all my boats that have CC ESC's setup in them and had no issues what so ever with calibrating WOT.
However, I am still using the older firmware (1.03 I think), that is obviosly where the problem lies
The 3S has two functions within the radio that allow for travel and trim + the normal throttle trim operation to be modified.
Before calibrating the ESC be sure that the trim control located to the left of the wheel is set to 0 on the main LCD menu, the sub trim is set to 0 and that the travel option within the radio's menu is set to 150 %.
I have performed this many times with no problems
BTW, why go to the new firmware in the first place ?
Jimmy
Come to the FASST side
hi folks
i upgrade firmware because i use mega motors that have 6 magnets
and i read that 1.03 version have problem with timing ......
i don't know if i can dowgrade to 1.03 ......
ok jimmy, i will check sub trim, but yesterday i already try with 150%
herve
I have calibrated my DX3R to a bunch of CC controllers with the throttle travel at 100% without a issue. It sounds like the ESC is the problem. Like others have suggested try downgrading the firmware to 1.03 and see if it will calibrate correctly.Team Liquid Dash
