how to power this charger
  • shannon87
    • 224
    hi guys recently purchased this charger http://www.hobbyking.com/hobbyking/s...r_Charger.html
    and im just wondering what do i use to power it since it doesnt have a wall plug and like 12mm banana connectors i was wondering if there was a way to use it without purchasing some kind of 12v battery.
    as i will be charging enough packs before i leave but another problem there is no balance point to charge all my 2s batteries.
    So how do i go about that unless it balances while charging as i have no idea because no manual came with the charger and its the first decent charger i was able to purchase thanks
  • oscarel
    • Dec 2009
    • 2373
    Easiest would be a converted computer power supply. Manual is at the bottom of the page you posted at the bottom just before the comments, click on file tab.
    Sent from my SAMSUNG-SGH-I997 using Tapatalk 2
    • shannon87
      • 224
      thanks oscarel ill check it out
      • egneg
        • 4759
        Here is an easy to follow "how to" I have made a few following this and they work great.
        IMPBA 20481S D-12
        • LiPo Power
          DJI Drone Advanced Pilot
          • 3678
          Or save yourself the hassle and get this:
          http://forums.offshoreelectrics.com/...-930W-77.5Amp-!!!
          Robert
          Canada
          • sanyijr
            • 377
            This is above and beyond what you need, but I have bought from his and he has great PS. 42A for $50. Go with the 42A version, way quiter!
            • LiPo Power
              • 3678
              My PS makes no noise. It has quiet mode mod installed. Turns slow
              And only kicks in when need it, also for $15 bucks more ( $65 ) and few more amps its a steel...
              IMO few extra amps wont hurt... More amps more chargers... :-)
              http://feathermerchantrc.com/
              Canada
              • 785boats
                Wet Track Racing
                • 3423
                But Robert, the one you posted the link to is $180.00 . Do you have a smaller one for the $65.00 you can post a link to.
                • LiPo Power
                  • 3678
                  Sure do, right here:
                  http://forums.offshoreelectrics.com/...-HP&highlight=
                  Thanks
                  Robert
                  Canada
                  • shannon87
                    • 224
                    thanks for the links robert definately have to invest in that as soon as i can can you post one to australia and if so how much and whats involved etc cheers
                    • LiPo Power
                      • 3678
                      canada and US
                      Canada
                      • shannon87
                        • 224
                        hi lipo well that leaves me out lol hopefully ill be lucky enough to get something from a LHS and egneg thanks for the link and idea but id have no idea what id be looking at or how to build it haha
                        • 785boats
                          Wet Track Racing
                          • 3423
                          Shannon.
                          I use one of these. I used to run two of those Accucell8 chargers off it with each one charging two 4s 5000mah bricks in parrallel. So about a 14A load.
                          Now I run a Hyperion Duo charger with two packs on each channel in parallel. That's about 20A. The power supply doesn't even get warm.
                          You need to put your own 240V power lead & output leads on it though.
                          15V/23A Switching Adaptor (Input 115V/230V) from manufacturer , in category Power Supplies (AC/DC adaptors/Power Panel/Power distributor), Battery Chargers & Battery Accessories.
                          Cheers
                          Paul.
                          • shannon87
                            • 224
                            hi paul thanks so much for that link im sure i could get the input and output leads on it how did you hook up the chargers to it since it has the banana plugs and i dunno how im going to balance my 2s packs cos thats all i pretty much run as i run 4s2p in series in all my boats but one.
                            • shannon87
                              • 224
                              i dunno maybe im better off buying a charger/balancer that i can use at home and take my accucel to the field incase i need to top off my packs.
                              And run it off my car battery dont see how them banana plugs can hook up to a car battery and still cant balance my packs so i might just try and sell it and stick with a home charger that can balance my 2s packs.
                              Any links to a charger that can do this would be great and wont cost me over a hundred bucks.
                              Cheers for all the help and unless i brought something like this http://www.hobbyking.com/hobbyking/s...40V_220W_.html and some sort of connection adapter so i can balance my 2s packs and when your chargng them do your packs have to be plugged into the balance ports aswell ?, sorry about all the newb questions but this is my first proper charger lol
