Power supply suggestions
  • RIPFENCE
    • Sep 2009
    • 1577
    I am going to invest in a new hyperion charger that will need a 24 volt power supply to take advantage of its full capability..i have done some quick research but i would rather listen to others here on the forum who have had good results...i am either buying the hyperion 1420inet3 or the 730inet3...i think the spec should be around 50 amp capable
    anyone using something like this for their hyperion chargers?
    Thanks
    rip
    "FE" STANDS FOR FRUSTRATING EXPLOSIONS
  • JIM MARCUM
    • Jun 2011
    • 775
    You might want to look at this: http://www.ebay.com/itm/LED-POWER-SU...item5ade5efa1a JIM
    JIM MARCUM: NAMBA 777; EX? SoCal FE Racers Club; D-19; Official 2012 NAMBA FE Nationals Rescue Diver; Purple Heart Viet Nam Vet; Professional SCUBA/HOOKA Diver, KELCO, 1973-1978; BBA 1978, Magna Cum Laude; MBA 1980 w/honors; Retired DOD GS1102-12 Contract Specialist
    • Snowride
      • 297
      Here is a nice unit how ever it does a max of 18v but can deliver 540 watts (30Amp) . http://epbuddy.com/index.php?main_pa...roducts_id=207 I use the smaller 300 watt (20Amp) unit which is adjustable from 6 to 12 and performs flawlessly. http://epbuddy.com/index.php?main_pa...roducts_id=207
      • RIPFENCE
        • Sep 2009
        • 1577
        Originally posted by snowride View Post
        here is a nice unit how ever it does a max of 18v but can deliver 540 watts (30amp) . http://epbuddy.com/index.php?main_pa...roducts_id=207 i use the smaller 300 watt (20amp) unit which is adjustable from 6 to 12 and performs flawlessly. http://epbuddy.com/index.php?main_pa...roducts_id=207
        looks like a good deal for the specs
        i belive in order for me to get the 550 watts out of the hyperion i need 24-30 volts..18 is not bad at all though for that cheap of a price
        max amps sells one that will do the job but its 150.00..maybe i can find out which one is just rebadged in the max amps packaging and cut out the middle man so to speak..
        Thnks guys
        • turbonutt
          • Mar 2010
          • 64
          What about 2 of the 47 amp server power supplies wired together? They are super easy to mod and you can pick them up for pretty cheap
          H&M Drifter L, AC Lightning Cat and a Graupner Jet Sprint waiting to be built
          • m4a1usr
            Fast Electric Addict
            • 2036
            Rip,
            Get two of the many available server PS and wire them together. You need 50 amps at 24 volts? Thats easy. For about $60-70 and an evening of adapting you can have all the power you need. But they can be a bit noisy if you havent built these server PS out there. I'm happy with mine. Just be aware they are noisy. Lots of air being sucked in. Also for a full 50 amps on 24 volts off 110vac wall power make sure you have a dedicated 30 amp outlet. The normal 15 or 20 shouldnt be trusted.
            John
            Change is the one Constant
            • oscarel
              • Dec 2009
              • 2373
              Here's all the info you'd ever need on converting them.
                Hears a link,http://forums.offshoreelectrics.com/...power-supplies!
                This is the one I have, Sounds like a hair dryer on low speed.
                But works good.http://www.ebay.com/itm/170615236018...=p5197.c0.m619
                • Snowride
                  • 297
                  IMHO I think the puter power supplies look like some poor boys after thought even though they work. Would much prefer to have a dedicated unit like the ones I posted for not that much more by the time you are done soldering and tinkering plus the fact they are small, quiet and super cool looking.
                  • HydroMike
                    • Oct 2011
                    • 338
                    These r vary nice two 12 volt PS to do 47 amp love mine http://forums.offshoreelectrics.com/...ht=#post397576
                    • jkr
                      FE Addiction
                      • 582
                      Or you can check.
                      http://www.ebay.com/itm/DC-Power-Rey...#ht_3171wt_887
                      • RIPFENCE
                        • Sep 2009
                        • 1577
                        thanks guys for all the good info now i have a lot to think about
                        • Cooper
                          • 1168
                          Thanks
                          rip
                          Unit Prices:
                          1~9 pieces $74.47 each
                          Higher Qty's: Request Quote
                          Output Specifications:
                          Output Voltage: 24 Volts DC
                          Min Current: 0 Amps
                          Max Current: 18.8 Amps
                          Power: 451.2 Watts
                          Input Specifications:
                          Input Voltage: $75.00 at trcelectronics.com. More amps if u want to spend more
