Can I use a 24V power supply with any charger?
  • Drax21
    • Jul 2011
    • 1077
    Question as above. I know most chargers only require 12V but will it hurt to use a 24V 13Amp power supply? Will this help balancing?
    Thanks
  • RaceMechaniX
    • 3024
    DO NOT USE A 24V POWER SUPPLY ON A 12V CHARGER! Unless you charger is rated at 24V input you should stay below the maximum input voltage. If you apply 24 volts to a 12V charger be prepared fro smoke.
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    • Drax21
      • Jul 2011
      • 1077
      Thanks for your reply. Please check this vid. Tell me what you think. http://youtu.be/sJsgJlGN7kk
      • RaceMechaniX
        • 3024
        The 208B according to its input specs is good from 4.5VDC to 32VDC so a 24VDC power supply is suitable.
        Tyler Garrard
        • Drax21
          • Jul 2011
          • 1077
          Thanks. It does seem to work good in that vid. I hear balancing on that charger is amazing and was wondering if I should get the same power supply. Q answered thanks
          • RaceMechaniX
            • 3024
            You can use a 12V or 24V as long as the power supply can deliver the current. The guy in the video is charging at 3C or 15A for a 6S 500mAh pack which is not recommended as good practice.
            Tyler Garrard
            • Drax21
              • Jul 2011
              • 1077
              Yeah I always have plenty of time on my hands so i charge at 1c
              • veejo
                • 28
                The DC chargers have inverts in them to step up the voltage and then recify, so if you have the 24V supply already, great, but I wouldn't buy one specifically and expect a different result. Most chargers will go to 18V input, so if you were going to buy a new power supply stick with 12/13.8V as it will give you the broadest selection of chargers to use in the future.
                Yes, I also only charge on 1C .... patience ..... we are not born with it, we learn it.
                That is also why 1 run 2 chargers off 1 powersupply (charge 2 batts at once at 1C), and they now make quad chargers which sell like hot cakes so you can gently charge 4 packs at once. At 1C who needs a temp probe ????
                Proboat Mystic, Proboat Impulse 31, Aquacraft Supervee 27, Aquacraft Atlantic tug
                Hello from Australia.
