Is there something wrong with this charger?
  • Chenige
    • Jul 2011
    • 201
    First time I am using a charger with read outs. Issue is I do not think I am getting full charge. Is the below normal?
    Discharged to 2712mAh using charger
    charged to 0431, charger stopped by itself
    rehit charge button, charged to 2059, stopped by itself
    rehit charge button, charged to 3078, stopped by itself
    This happens on 3 brand new NiMH 3800 batteries.
    Discharging and charging at 3.8A.
    thanks
  • JimClark
    • 5913
    might help to know what charger it is?
    Billy Graham
    • Chenige
      • Jul 2011
      • 201
      Integy 16x910
      • 7500RPM
        • 110
        The Drop back voltage is set to low, can't find a manual on line to see what the factory default is. Also there is a lockout timer for the start of the charge 0 to 10 minutes in most cases, user selectable. Most Nimh I set to approx 15 mV for the entire pack ( 6 cell )
        There is no replacement for displacement, I guess I just have to Buzz it higher!
        • Chenige
          • Jul 2011
          • 201
          I took a look at the directions and I do not believe there are any user adjustable features except charge and discharge rates, type of battery and cell #. Also a discharge/charge cycle repeat of 2 to 99 times.
          So off it goes back to the company.
          That is the issue with something new. Just not sure if it is the equipment or you are not doing it right.
          • 7500RPM
            • 110
            Most Integy chargers have a option for changing NiMh drop back or Delta Peak settings.
            • 7500RPM
              • 110
              Integy INDI 16X910 Multifunction All-In-One Charger. Microprocessor controlled high power output AC/DC battery maintenance system, exclusive opto sensor switches for touch-less operation, individual cell balancing, 1S to 8S for Li-ion, LiPo and LiFe, 1 to 24 cell for Ni-Cd and NiMH, delta-peak sensitivity, Pb chemistry capable, wide range of charge current, input voltage monitoring, charge and discharge data storage, shows previous memory on pack's capacity, helps with battery break in and cycling, input voltage: 11~15VDC or 110~120VAC, circuit power: max charge: 1800W in DC mode and 100W in AC mode / max discharge: 50W, charge current range: 0.1~10.0A, discharge current range: 0.1~10.0A, 4mm banana plug power output, universal pin type balancing adapter, firmware update possible using PC connection, 1-year limited warranty
              • Chenige
                • Jul 2011
                • 201
                Not sure what you are trying to say? It does have delta-peak sensitivity but is not adjustable as far as I can tell, if that is what you mean.
                Issue seems to be it is not going up to peak charge.
                • 7500RPM
                  • 110
                  The information on the charger says" delta-peak sensitivity" than it is adjustable, it is going to be in the NiMh profile options, I do not have a manual to see it, so you have to look carefully for this.
                  • Chenige
                    • Jul 2011
                    • 201
                    I cannot figure out how to adjust. It is not in the directions that I have.
                    So, I am sending it back for service.
                    thanks
