charger power supply
  • byron
    • Dec 2010
    • 65
    i have a 1000 watt inverter that is 12vdc 120a max ,will this be big enough to supply a charger?
  • Alexgar
    • Aug 2009
    • 3701
    i dont think so laptop ps are cheap and my 6.5 amp toshiba is beefy
    • sailr
      • 7128
      Yes, of course it will. You sure it will put out 120A? That sounds like a lot, like a big commercial power supply. At 1000 watts, you can charge a 6S pack (22.2V) at 45A! I doubt seriously your charger will put out 45A!
      Mini Cat Racing USA
      www.minicatracingusa.com
      • byron
        • Dec 2010
        • 65
        well i don't know all the electrical jargan but it reads,on the input side 12vdc/120a max and on the out put side (the side with the plugins) 115vac 60 hz 1000w. the bottom reads
        output power maximum 1000w/8.7 a continuous. so what ever that is in english .
        • Eric Bourlet
          • Jan 2010
          • 104
          Watts=AmpsxVolts
          so it looks like 1000 watts/8.7 Amps=115volts
          So the bottom sticker is the input ratings.
          If you take 12volts x 120 Amps=1400 Watts
          You cant get more out than you put in so there is a problem here. I think the 120 Amp on the 12 volt side is most likly a peak measurement.
          I would imagine that you could get 70 amps out though.
          Eric Bourlet
          Team Airtronics
          Team M&D Designs
          • byron
            • Dec 2010
            • 65
            hi eric
            just wondering if you have any extra hk 120 a marine esc.? they have been on back order for a long time.
            • Eric Bourlet
              • Jan 2010
              • 104
              No after I burnt up the one at the FE race in Granite Falls I switched to a Castle Ice 100 that I water cooled. I like the logging capability. Sorry
              Eric Bourlet
              Team Airtronics
              Team M&D Designs
              • sailr
                • 7128
                That "output power' of 8.7A is the giveaway. You could charge up to 8A ok, but no more. Pretty limited. I used to use 14A power supplies that would shut down if I tried charging at 10 Amps!
                Mini Cat Racing USA
                • sailr
                  • 7128
                  I just read your first post again. It's an Inverter! You mean you want to hook it to a battery and then plug in a 110V charger to it? Different ballgame.
                  Mini Cat Racing USA
                  • norbique
                    • 367
                    I just noticed that too, it's an inverter :) Makes AC from DC. You need the opposite of that. A Switching PSU making DC from you wall socket.
                    For those who have the knowledge and the motivation there's a very good instruction on how to build a 13.8V 40A constant 60A surge switching PSU. The instruction is very easy to follow. I finished mine a month ago. It took me quite some time, but at least I can say I built it. And I can/know how to repair it if anything goes wrong and the inevitable happens.
                    I've killed a number of converted old PC PSU's. Killed most of em by accidentally pulling more current than what they were designed for. So I got tired of converting old PSU's and wanted to make something dedicated and more powerful. I also charge A123 packs at 10+ amps and high cell count packs really need the power.
                    Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it.
                    - Mark Twain
