Warning: Trying to access array offset on null in phar://.../vb/vb.phar/bbcode/url.php on line 2 Lipo Load Bank for Discarging (moved from swap shop) - RcBoaters Forum
  • longballlumber
    • 3417
    I wanted to bring this back to the top. I am looking to build one of these.
    I would be willing to build 2 at the same time if someone was interested. Since Tyler posted his prices have gone up and parts alone one would cost $250 not including shipping. Is anyone interested? If not I will only buy enough parts for myself.
    2 of these resistors: http://www.alliedele...k1r0e/70022401/
    1 of these heat sinks: http://www.alliedele...06000/70115158/
    Thermal grease if you don't already have it: http://www.alliedele...-150g/70125596/
    2 of these fans: http://www.alliedele...624hh/70104890/
    Thanks
    Mike
    Links don't work for me but, may work for others.
      I was maybe thinking of building one since I have everything except the resistors. What is the price at alliedele for resistors?
      • longballlumber
        • 3417
        $76 x2
        http://www.alliedelec.com/ohmite-tap600k1r0e/70022401/
        • JMSCARD
          • Mar 2010
          • 4174
          So what would the total cost be, just wondering... I find it a huge pia to discharge my larger packs, no super quick way to do it... and often I bite off more then I can chew when I charge more lipos for the day then I end up using...
          • longballlumber
            • 3417
            After sleeping on it, I am going to retract my offer. There really isn't any benefit buying parts for one assembly or two. However, I fixed the links below. The total cost is just a hair under $250 (shipping NOT included). Thanks again to Tyler, I am simply regurgitating the info he provided directly to me.
            2 of these resistors: http://www.alliedelec.com/ohmite-tap600k1r0e/70022401/
            1 of these heat sinks: http://www.alliedelec.com/aavid-ther...6000/70115158/
            Thermal grease if you don't already have it: http://www.alliedelec.com/mg-chemica...150g/70125596/
            2 of these fans: http://www.alliedelec.com/ebm-papst-624hh/70104890/
            • TRUCKPULL
              • 3293
              I use a set of 8 of these in series for my 2S and 4S packs.
              6 of these in series would be good for 6S packs.
              http://ca-en.alliedelec.com/arcol-hs50-2r5-f/70596828/
              I forgot to say, you can also use these to cook on.
              Larry
              • RaceMechaniX
                • 3024
                Anytime Mike,
                I also want to stress I would not recommend using these unattended. The loads banks will draw about 22A@35V when wired in series and 45A@20V when wired in parallel. It only takes several minutes to fully dump a 5000mAh battery and it's very easy to walk away and forget.
                I recommend using these through a charger capable of controlling the discharge like an iCharger Duo. This will safely monitor voltage and temp of the discharging battery.
                If you do use it as a standalone discharger, please invest in a simple cell checker with low voltage buzzer.
                Tyler
                Tyler Garrard
                NAMBA 639/IMPBA 20525
                T-Hydro @ 142.94mph former WR
                • longballlumber
                  • 3417
                  Well, I finally got mine assembled and started "fiddling" around with it last night. Should be a pretty good tool, but still have lots to learn. Thanks again to Tyler to helping me along the way!
                  • Darin Jordan
                    • 9446
                    Mike, I just finished mine up as well (THANKS TYLER!!)...
                    Even came up with a way to add some rubber feet to it. I can thread in 1/4-20 Furniture posts/feet into these rubber inserts, if desired. And I added a pair of 4mm taps, in case I decide (probably won't) to run the fans off the load, rather than the power supply, or for plugging in a voltage monitor of some kind.
                    Is that the iCharger S/W you have there on your laptop??
                    Mine is setup in parallel, since I don't generally use anything over a 4S pack, and my 6S setups use two 3S packs.
                    Darin E. Jordan - Renton, WA
                    • Darin Jordan
                      • 9446
                      I think the prices must have gone up... My parts cost $317.00 shipped, and I probably have another $80+ in wire, contacts, etc. A lot, I know, but sometimes, you just have to pay to play the game, and this will have enormous benefits for Time-Trials and heat racing, as well as general battery management.
                      • longballlumber
                        • 3417
                        The Feet are a good idea. Mine was already sliding around on my work surface. The third fan is probably a good idea too. I was discharging a 6S pack last night and that aluminum heat sink got up to 185F! I need to make different jumpers for parallel too. Although I do have some 6S packs I will be using 4S mostly.
                        The software on the laptop is LogView. I don't know much about it, but it seems to be a freeware/shareware type tool. I think they Hyperion's use the same software. Just another thing for me to learn.
                        Later,
                        Ball
                        • Darin Jordan
                          • 9446
                          Thanks, Mike!
                            185F, whoa! Those are huge heat sinks. What about fans on the other side to speed up air flow?
                            • longballlumber
                              • 3417
                              When you think about it; it's ALOT of energy that is being turned into heat in only a few mins. I don't suspect you will get the actual "peak" temp down, but more fans would minimize how long that "peak" is sustained. Once the load ramps down the 2 fans cool everything very quickly.
