I see many people are running 1527 1.5y 850 kv motors in a 1/8 scale hydro and using 2 5s batteries for 10 s with around 5500 MAH and castle creations says you need 10,000 MAH or you will trash the ESC no way enough room for 5 - 5s batteries in my winston eagle so whats up with that ?
Mah
Tags: None
It's basically Castle's way of ensuring you have a sufficient power source to draw from. Castle controllers are a little weak compared to others when it comes to buffering the input voltage/current. 2P generally results in a "stiffer" power source.
Just make sure to use short wires, good connectors and good batteries.
TGTyler Garrard
NAMBA 639/IMPBA 20525
T-Hydro @ 142.94mph former WR
Thanks Tyler that's what I thought but wasn't sure and I can't afford a shults so I got the castle hydra ice 200 hvOriginally posted by RaceMechaniX View PostIt's basically Castle's way of ensuring you have a sufficient power source to draw from. Castle controllers are a little weak compared to others when it comes to buffering the input voltage/current. 2P generally results in a "stiffer" power source.
TG
Be particularly careful with that model. They are capacitor limited. There are a couple of threads in the scale section on alternate controllers including the Etti 220HV pro. If you already have the Castle it is worthwhile to add 1-2 extra caps on the input leads near the controller.
Here is an example on a Schulze: WP_002690.jpg
You can also use the Castle one: CCCapPack2.jpgTyler Garrard
thanks Tyler I have already added the castle capacitor bank on itOriginally posted by RaceMechaniX View PostBe particularly careful with that model. They are capacitor limited. There are a couple of threads in the scale section on alternate controllers including the Etti 220HV pro. If you already have the Castle it is worthwhile to add 1-2 extra caps on the input leads near the controller.
Here is an example on a Schulze: [ATTACH=CONFIG]132788[/ATTACH]
You can also use the Castle one: [ATTACH=CONFIG]132789[/ATTACH]
Tyler, what connectors are you using for your battery leads ?\Originally posted by RaceMechaniX View PostBe particularly careful with that model. They are capacitor limited. There are a couple of threads in the scale section on alternate controllers including the Etti 220HV pro. If you already have the Castle it is worthwhile to add 1-2 extra caps on the input leads near the controller.
thanks.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
I use either the Jet 6mm or LMT 6mm plugs.
BTW, neither of those pics are of my equipment, just pics I grabbed quickly off Google.Tyler Garrard
