Mah
  • meangenesracing
    • 1332
    Mah
    I see many people are running 1527 1.5y 850 kv motors in a 1/8 scale hydro and using 2 5s batteries for 10 s with around 5500 MAH and castle creations says you need 10,000 MAH or you will trash the ESC no way enough room for 5 - 5s batteries in my winston eagle so whats up with that ?
  • RaceMechaniX
    • 3024
    It's basically Castle's way of ensuring you have a sufficient power source to draw from. Castle controllers are a little weak compared to others when it comes to buffering the input voltage/current. 2P generally results in a "stiffer" power source.
    Just make sure to use short wires, good connectors and good batteries.
    TG
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    • meangenesracing
      • 1332
      TG
      Thanks Tyler that's what I thought but wasn't sure and I can't afford a shults so I got the castle hydra ice 200 hv
      • RaceMechaniX
        • 3024
        Be particularly careful with that model. They are capacitor limited. There are a couple of threads in the scale section on alternate controllers including the Etti 220HV pro. If you already have the Castle it is worthwhile to add 1-2 extra caps on the input leads near the controller.
        Here is an example on a Schulze: WP_002690.jpg
        You can also use the Castle one: CCCapPack2.jpg
        Tyler Garrard
        • meangenesracing
          • 1332
          thanks Tyler I have already added the castle capacitor bank on it
          Here is an example on a Schulze: [ATTACH=CONFIG]132788[/ATTACH]
          You can also use the Castle one: [ATTACH=CONFIG]132789[/ATTACH]
            • 9481
            Tyler, what connectors are you using for your battery leads ?\
            thanks
            • RaceMechaniX
              • 3024
              I use either the Jet 6mm or LMT 6mm plugs.
              BTW, neither of those pics are of my equipment, just pics I grabbed quickly off Google.
              Tyler Garrard
