Revolectrix
  • Peter A
    • 1498
    #31
    I just ordered 4x 2s 5500mah hv packs this morning. Looking forward to run them. Hoping they will be here for next club day Oct. 5th.
    They are here! First thing Monday morning. Why do I have to work...?
    They have my name on the label too!
    • Peter A
      • 1498
      #32
      Just like all new Lipos, you should cycle them under a light load a few times before you go out and really work them hard.They will last longer.
      Can the cycle function on my charger do this? If so can I cycle all 4 2s packs on a board together?
      • 785boats
        Wet Track Racing
        • 3169
        #33
        Yes.
        Some people cycle them 4 or 5 times at a 1C charge & discharge rate.
        There will be many variations & preferences by many people, but here's what I do.
        Charge it up at 1C & note the IR & voltages of each cell.
        Discharge at 1C down to 40% remaining. Check how closely matched the voltages of each cell are.
        Charge up again & check the numbers.
        Then I put it in a boat that I know has a light current draw. Our restricted boats are perfect with about a 50A draw.
        Run the boat for about 1 minute leaving about 60% in the pack. Nice & easy, no hole shots or sudden accelerations that will spike the amps.
        Let the pack rest for 20 minutes. Recharge the pack
        Run it again lightly down to 40% remaining.
        Let it rest, recharge.
        Then it can be used in a higher powered boat. But for the first few runs I still use easy accelerations & try not to go below 40% remaining.
        After that, I have no trouble with going hard on them.
        After each run, it's good to check how close the cell voltages are with each other. And at the end of each charge take a note of the IR of each cell.
        Incidentally, the IR should usually drop a bit from the initial charge readings after the first few light runs. That's a good thing.
        Like I said, that's just what I do. I'm in no way saying that it is the best way, but it works for me. Any sort of light cycling is better than none.
        • Doug Smock
          • 5264
          #34
          the sticker does not say 3.8v nominal....
          Are these the HV cells? According to the website the "Silver Label"HV cells are 70C. Or am I missing something?
          MODEL BOAT RACER
          IMPBA President
          IMPBA 19887L CD
          NAMBA 1169
          • Make-a-Wake
            FE Rules!
            • 5554
            #35
            The photo in the first post shows them to be legal. The sticker reads - 6s 22.2v = 3.7v according to my small brain
              Yes sir. This is a silver label 70c battery. (I took it apart to make a single cell battery because they don't sell a single cell) I'm no expert but my thought process is the cells started life as a 5000mah 65c cell at 4.20 full charge. Then they took the same cells and did some sort of coating or something to keep them from gassing when charged to 4.27v....then at 4.27v they are re-rated. I could just be full of it but it makes sense to me.
                Chris...did you run today? If so, how you like them?
                • flraptor07
                  • Aug 2013
                  • 2451
                  #38
                  Yes I did, I ended up running the 6s packs in my Ariane Q mono. I ran my two old Hyperion packs in it first then the Revolectrix, I forgot my GPS but you could tell a pretty big difference in the sound and looked to be faster. Plus it came in with everything about 15deg. cooler. So my answer is yes!! I really like these packs
                  • Doug Smock
                    • 5264
                    #39
                    Shy of a magic wand I'm not sure how 65c cells that have been assembled become 70C cells.
                    John can you clear this up for us?
                    MODEL BOAT RACER
                    IMPBA President
                    IMPBA 19887L CD
                    NAMBA 1169
                    • flraptor07
                      • Aug 2013
                      • 2451
                      #40
                      This is the video of the first run on the Hyperions, he didn't get the video of it with the Revolectrix. https://www.youtube.com/watch?v=yhMK...ature=youtu.be
                        You wouldn't agree that when you put the extra voltage and capacity in it that it could increase the C rating? I'm pretty sure that's where it's coming from. To be honest, I'm really not worried about the 5c....the beat the pants off the most impressive batteries I've ever run that were 65c....the spc packs I had. Had I never talked to John and tried a set of them...I'd still be running spc. I sold all of my batteries and replaced them with revolectrix if that says anything lol!
                          That thing was moving. Wish you would have video the revo batteries. A guy on here did pick up 2mph with the revolectrix after a couple cycles. I'm cycling all my batteries right now. Lol
                          • Doug Smock
                            • 5264
                            #43
                            Well Travis that's why I asked John to clear this up.
                            Personally I would expect the label on the inside of the pack to match the label on the outside.
                            If it makes any difference I have some of these. Am I convinced they are any better than some other cells I have? No, not at this time. Perhaps I'll have a better idea when I have spent some more time running them through the lie detector.
                            I'm glad you're happy with them and I hope they give you 300+ cycles.
                            MODEL BOAT RACER
                            IMPBA President
                            IMPBA 19887L CD
                            NAMBA 1169
                              John may stop by and give his take on it. What cells have you compared that perform as well? I'm always looking for options. Hows the price compared to the revolectrix? How many cycles have you got on your revolectrix? Have you had any problems?
                              • Doug Smock
                                • 5264
                                #45
                                I have had excellent results with Hyperion. Not sponsored, no special deals, just results and longevity.
                                Like I said. For me the jury is still out, not seeing anything exceptional so far.
                                I'll be spending more time with them this weekend. Going to run some boats through the lie detector.
                                Thank goodness I got the piece parts from Hyperion John, or I wouldn't be able to run the Revos.
                                D.
                                MODEL BOAT RACER
                                IMPBA President
                                IMPBA 19887L CD
                                NAMBA 1169
