Revolectrix
    • 9479
    So Pete. Are they legal for your club racing?
    charged to 4.2v per cell and they are 100% legal
    • flraptor07
      • Aug 2013
      • 2451
      For NAMBA if you running them 4s 2p you would be over the 10,000mah limit so they would not be legal. That's why I got the 4800mah 6s packs instead of the 5500mah packs for my Q set ups. But you Aussie guys are only allowed 1p so you're good to go!
      • pescador
        • 499
        I just ordered two of these 5000mah 60c 10s packs to run in parallel in an 1/8th scale.
        With a Neu 2230 and a Swordfish 300, its over 9lbs. for motor, esc and batts. OMG
        Namba District 16
        1/8 Miss U.S., 1/8 59 Maverick, 1/8 Executone, 1/8 Smokin Joes, MLGSX380, AC Pro40II Q Sport, AC Pro40II nitro,Twincraft mono 10s, Vision AOPC, VS1 FE, M34.
          The 5500 are actually a 5000mah cell if only charged to 4.20
          Anyone wanting to buy these batteries, pm me and I'll give you a coupon code for 10% off......
          • 785boats
            Wet Track Racing
            • 3169
            Unfortunately our rule book only states a max NOMINAL voltage of 3.7V/cell not a max charge voltage. And because the sticker on the packs states 3.8V/cell NOMINAL, people here deem them illegal. Even though when only charged to 4.2V/cell the nominal voltage is still 3.7V. In fact John from Revolectrix has stated that even fully charged the nominal voltage is still really 3.7V. The sticker was to differentiate the HV packs from their other packs.
            The lipo chemistry itself dictates the nominal voltage & the basic chemistry hasn't changed. It's just got a ceramic coating on the anodes that prevents gassing when charged to a slightly higher voltage. That's all.
            Our AMPBA is looking to add some 'wording' to the rule book to cover this new technology. We'll have to wait & see if the wording allows them or bans them. It will be a sad day if they ban them.
              the sticker does not say 3.8v nominal....
                • 9479
                interesting that people want to complain about old rules trying to apply to new technology...
                all John needs to do is make proper labels
                • 785boats
                  Wet Track Racing
                  • 3169
                  Sorry but the sticker does not say 3.8v nominal....
                  Sorry. My poor wording in the previous post. The outside sticker on, say, a 4s pack states 15.2V which equates to 3.8V/cell. That's what the scrutineers see.
                  But that pic is the first time I've seen the rating on the actual cells.
                  That is encouraging information for the technical side of things.
                  What are you doing pulling packs apart so soon? But thanks for that.
                  Todd.
                  No ones actually complaining. They just want to get it all sorted out to avoid any problems at the lake. Storm in a teacup as far as I'm concerned.
                    • 9479
                    Todd.
                    I think our lipo tech stuff is advancing faster than our rules are keeping up with
                    we have come a long ways since the 3.7v rule came into the hobby
                      Todd.
                      Lol, no worries. I was pretty sure no one is like me and gonna take a 5 minute old battery pack apart! The reason I did it was to run 7s in my rivercat. All of the 4s packs I've had won't fit so I made a Y connector and added one more cell in. Now that I own a few 4s revolectrix packs I know they fit so I no longer have to do this. But I knew this pic would be pretty interesting to you guys! It's basically a 5000mah, 65c cell that's coated with something (just repeating what was said about the chemistry) and it's able to be charged more and therefore output a touch more power and have a longer runtime.
                      Can I level with you guys? In the testing I've done, at 4.2v these batteries are noticeably more powerful than all other batteries I've tried. A 4.27v with 7 cells I picked up exactly one mph. Is that enough to ban these batteries? You can pick up 1mph by moving your strut, changing props.....so you be the judge.
                      • flraptor07
                        • Aug 2013
                        • 2451
                        First charge up on Revolectrix from Storage voltage
                        The first charge from storage voltage looked great, I used my new Elangears Elan R X2 charger http://www.elangears.com/?page_id=78...preview_id=789 the 6s packs with the charger set @ 8amp and 4.27 cut off per cell took 35min. to put 3624mah in a 4800mah pack with .008volt difference over 6 cells on one pack and .006 on the other pack with about the same time and mah. The 4s packs with charger set @ 6amp and 4.27volt cutoff per cell took 38mins. to put 3976mah in a 5500mah pack with .004volt difference over 4 cells on one pack and .003volt on the other pack. So far the Revolectrix packs and the new charger look great, we'll see how the packs perform tomorrow. And I'll give you the charging results as soon as I recharge the packs for the next use.
                          Come on man....go run those things! Lol
                          I'm about to head to the lake myself.
                          • 785boats
                            Wet Track Racing
                            • 3169
                            Just like all new Lipos, you should cycle them under a light load a few times before you go out and really work them hard.They will last longer.
                            But with your new charger, get into the habit of noting the Internal Resistance of each cell at the end of each charge. Initially they will all be pretty close, but as the battery gets older you can see if a cell starts to build up a higher resistance than the others which can tell you that a problem may develop down the track. A high resistance cell is usually the one that drops to a lower voltage than the others during a discharge in the boat, & takes longer to balance up to the other cells during a charge.
                            • Peter A
                              • 1498
                              Yep, we just run open electric for club day. Our current rules allow up to 2p 12000mah. We keep it fairly simple here. We have only a pretty small fleet of fe as gassers are predominant. I have a dirty little secret, I am building a petrol offshore boat at the moment. It's 54" long and powered by a 264 rcmk. I really just want to annoy the gassers a bit more by beating them at their own game. Probably could have built a couple of new fe boats for the money but!
                              • 785boats
                                Wet Track Racing
                                • 3169
                                Cool with regards to the batteries.
                                Give those gassers heaps man.
