Balancing problems
  • jamespl
    • 748
    Balancing problems
    Just got a new turnigy 6000mah 2s lipo and it charged ok but the cells were reading 4.20v and 4.0v I have set it to just balance but it doesn't seem to go above 4.04v on the one cell. Should I just leave it or would discharging it and recharging it help?
  • dana
    • Mar 2010
    • 3660
    have you tried a different charger?
    • jamespl
      • 748
      I only have the one. Turnigy accucel 6. I think it may be time to upgrade anyway. I've got it on discharge at the mo and the cells are within 0.03v of each other now.
      • dana
        • Mar 2010
        • 3660
        I've had packs do the same thing. Ok at low voltage but won't go past a certain point when charging. I always toss them....
        • jamespl
          • 748
          I think this may be the same thing. This was a replacement one as I had a puffed pack from new in my last order. I think it's time to stop buying packs from hobbyking!
          • Snowride
            • 297
            I had one like that and brought it back by recharging several times. Took about 6 attempts and it came back and now seems to behave normally. I did not drain them, simply balanced charged them again as if they needed charging even though they were topped off. Gained about .02-.03v after each new charge. Give it a try, worked for me using an icharger 206b. Out of the 12 packs I have from HK, this has never happened to a Nano tech this happened to a cheaper version Turnigy but like I said it was revivable. Cheers
            • jamespl
              • 748
              I will have a play with it. I've got the voltage to 4.20 and 4.11 now.
              • electric
                • 1973
                There is a balancer called an Astro Blinky that does a great job of balancing cells. I use a turnigy charger with balancing plugs and have not had good luck with them. I just charge them without the balancers and let the Astro Blinky do the rest.
                • LiPo Power
                  DJI Drone Advanced Pilot
                  • 3678
                  Use the battery untill close to your LVC and ballance charge again.
                  Maybe couple of cycles will format the chemistry....
                  Canada
