Turnigy Nano-Tech VS. Thunder Power?
  • properchopper
    rcgoatbuild@snotmail.com
    • 6958
    Originally posted by Punisher 67 View Post
    Tony that thunderpower tour was a great read thanks for posting but realisticaly a lot of young boaters absolutely cannot afford them - Wife , kids , bills , etc put a huge damper on the hobby budget . I can see a racer that pushes his cells to the ragged edge the thunderpowers being a great investment or the saws racer looking for every little bit of edge he can muster .
    Peter, no doubt that "premium" batteries are somewhat overkill for sport boating. I use budget batteries for fun, but as of this year racing in my district (NAMBA 19) has grown substantially. The two SAWs in L.A. can be accomplished with a budget battery ( I used some GenAce packs at the last SAW) ; most any battery will hold it's nominal voltage when early in their use cycle so that's what I've been using. Also the spec class boats don't put a high demand on the pack(s) so my Spec boats normally use Turnigys or GenAces. For my full-bore P-Mono it's Thunderpower all the way and I'm going into my second season with my TP's in that class.
    FWIW , besides my income from rcboatbuild, I have two other part-time jobs, at least half the proceeds of which go into a savings account for batteries at the beginning of each race season. You gotta work hard if you wanna play hard !
    A few of us in SoCal FE have just made a bulk purchase of what we hope are high-performance packs from a Chinese supplier that look very promising. I'll disclose the results after they arrive and are put to the test
    • Punisher 67
      Ignore list member #67
      • 1481
      That would be coool Tony - thank you
      Necessity is the mother of invention.............
        • 9479
        what name is on them Tony?
        • Drax21
          • Jul 2011
          • 1021
          Hey Tony would you be talking about POWER PLUS batteries? I have heard of a massive factory in China who have recently in the past 6 months developed LIPO Batteries for RC which they believe rival the best.
          • properchopper
            • 6958
            Power Plus Batteries can be obtained from Shenzhen Tianline Technology Company Ltd. in Guongdong, China. They are made up from Samsung cells. The ones I am getting are not these. I'll disclose more soon - be patient
            • LarrysDrifter
              Big Booty Daddy
              • May 2010
              • 3278
              I havent done any testing between the two brands of packs, but ive have both and can say I wont be buying either again. The nanos always puffed and the Thunder Powers split the hard cases when they swelled and became about 3" thick. I use regular Turnigy packs and have had no problems with them.
              • Drax21
                • Jul 2011
                • 1021
                I have only used regular Turnigy packs so far with no problems. I have used 1 Thunder Power 2s battery and it also swelled. I have a local dealer in the UK for Power Plus Batteries , has anyone tried them?
                • detox
                  • 2310
                  Running packs down TOO low will cause anypack to puff. I try not to go more than 65% below rated capacity.
                    • 7651
                    Just my 2 cents here.I'm running Sky's and a set of TP 5000's.After this season(not too many runs),the Sky's take alot longer to balance at the end of the charge.I bought a set of each at the same time so I could monitor and come to a conclusion as they age.
                    • sailr
                      • Nov 2007
                      • 6924
                      I have had much bettter luck with the regular turnigy packs and the Sky Lipos than the Nanotechs and Thunderpowers. However, that being said, HYPERION's are the ultimate packs that I own. More expensive but last three times longer at least and always balance out.
                      Mini Cat Racing USA
                      www.minicatracingusa.com
                      • Drax21
                        • Jul 2011
                        • 1021
                        Yeah, I never run my packs below 3.3V I always use Lipo Protectors.
                          • 9479
                          I agree..
                          with FE boats I run them to 70-75% and my 3D planes I run them 75-80%
                          if that's resting volts, it's very possible you have run them beyond 90-95%
                          cuz that's only 6.6v for a 2s pack and 9.9v for a 3s pack
                          • Drax21
                            • Jul 2011
                            • 1021
                            I agree..
                            Thing is my Turnigy batteries are all fine, and a Seaking Esc is normally set to cut off at 3.3V.
                              • 9479
                              thing is, if your lvc is set to 3.3v then your resting volts is higher
                              so most any packs would be just fine
                              • Drax21
                                • Jul 2011
                                • 1021
                                So what I get from this....is that my TP packs should not have swelled after about 15 cycles.
