Need some help
  • roadrashracing
    • 1630
    Need some help
    Heres my problem, my boat runs 7 cell battery packs and by 1/8 buggy runs 6 cell packs. I am trying a way to wire the packs so I can run them in both, with out have to mess with wires all the time. Would it work if I just add a plug like I have shown?
  • 1truckerdan
    • Aug 2011
    • 344
    I think it would work, but.....one cell would not end up with the same amount of cycles on it.
    daniel
    When you know it all.......you never will learn anything new
    • dana
      • Mar 2010
      • 3660
      Run 7cell in your buggy
      • roadrashracing
        • 1630
        the esc on the buggy can oly handle 2 6 cell packs and the boat does not run well with 6 cell packs.
        • DBQuick
          • Aug 2011
          • 55
          You need 2s or 3s and up to run boats
          • jstolz
            • 377
            I would make two packs from the 7 cells. Take the seventh cell out of the pack and make a 6 cell pack. I have no idea what type of connectors that you have on the battery. I use bullet connectors on my battery packs. Put a positive and negative connector on the 6 cell pack. Put a positive and negative connector on the seventh cell. If you want to run 6 cells, use the 6 cell pack. If you want to run 7 cells, connect the negative connector of the 6 cell pack to the Positve connector of the single cell.
            I hope that helps.
