Heres my problem, my boat runs 7 cell battery packs and by 1/8 buggy runs 6 cell packs. I am trying a way to wire the packs so I can run them in both, with out have to mess with wires all the time. Would it work if I just add a plug like I have shown?
Need some help
Tags: None
I think it would work, but.....one cell would not end up with the same amount of cycles on it.
danielWhen you know it all.......you never will learn anything new
the esc on the buggy can oly handle 2 6 cell packs and the boat does not run well with 6 cell packs.
I would make two packs from the 7 cells. Take the seventh cell out of the pack and make a 6 cell pack. I have no idea what type of connectors that you have on the battery. I use bullet connectors on my battery packs. Put a positive and negative connector on the 6 cell pack. Put a positive and negative connector on the seventh cell. If you want to run 6 cells, use the 6 cell pack. If you want to run 7 cells, connect the negative connector of the 6 cell pack to the Positve connector of the single cell.Originally posted by roadrashracing View PostHeres my problem, my boat runs 7 cell battery packs and by 1/8 buggy runs 6 cell packs. I am trying a way to wire the packs so I can run them in both, with out have to mess with wires all the time. Would it work if I just add a plug like I have shown?
I hope that helps.
