power=torque x radians/minute (radians/minute = rpm x 2pi)
Obsession with 6s
I'm glad you're having fun with the Velocity! Still amazed about that motor! Dang! I knew they were a good motor but never would have guessed that good!Mini Cat Racing USA
www.minicatracingusa.com
I was a total FE boat newb when I came here.
When i converted over from nitro & gas to FE I started with a stock SV27 It was fun but wasnt much if any faster than my nitro boats. I ended up selling it because I didnt like how it would flip over so easy.
Later I sold my nitro and gas boats. Then got a UK boat called the saga. An EKOS clone type with slightly different electronics & motors. I ran it on 2 3S 45C packs. One 3S pack for each motor and esc combo. It was fun doing in the 30-40mph range and trying different props. Eventually I bumped it up to 4S and changed out the motors and props again. I got it up to about 62mph. That was pretty sweet.
After that I got the spartan and was taking the two 45C 3S packs I had and running them as 6S. That boat was in the high 50's after much modification. Not to impressive for 6S compared to my faster 4S cat. I ended up selling the spartan because I wanted another cat as ive never been a big mono fan.
So then came the Geico. I read some post and watch a bunch of videos with the geicos. Most of them were in the 40-50mph ranges. I wanted to get one that was mine into the 60's. So since I already had a T180, castle 1520 & later a 1518 I planned to put these in a geico and run 6S.
Mainly because I was aware that when you up the voltage in a system you lower the amp draw. These decisions were made because the 3S packs I had were 45C 5000mah. and the 4S packs I owned at the time were only 25C 4500mah. I felt I'd utilize what I had at the time instead of buying new motors and new packs.
Since the Miss geico I have invested in a few other lipo pack pairs and one is a 5S. I currently run my Miss geico with a 1518 on 5 & 6S. Its in the 55-63mph range.
I have also invested in a data logger because I was curious to see what was going on because I like to learn as much as I can. Mostly on my own because there arent any local boaters here in my area. Just a long drive away. Heck you learn better from experience anyways. Well with that data logger I have seen amp spikes on the MG that I really dont care for. My temps are always good. But the spikes are alarming. So I am currently trying a few ideas with the MG and might end up where I want to be with it.
Between all of this I have bought a CF daytona hull that i plan on building a twin out of during this coming winter. I originally wanted it to be a 6S boat because when I bought it I was playing with the spartan. But its now back on the drawing board and being thought out again. I do want that boat to run 80+ mph and look good doing it thats the goal and it will be achieved.
Currenty I have began a 32" cat build thats a twin and it will be a 4S boat. Its somewhat based on my 32" saga cat that started this need for speed craving. But this will be a little stronger boat with better motors, esc's, hull reinforcements, props and lipos. Its target will be a 70+ mph boat.
So basically I have run between 3s to 6S in my relatively new involvement in FE boating of my RC hobby. I have seen twin 4S boats do over 80mph and 6S boats struggle to hit 50mph. What it all boils down to is experience, learning, & knowledge. They all go hand in hand and one leads to the other. Plus you have to have a passion for this stuff otherwise you might get turned off if what your doing isnt working and you dont try to learn anything more than what you know & blame the equipment as the problem.
Honestly I feel this year the biggest 6S craze on this forum has probably been attributed to the Traxxas spartan. It has brought lots of new people to the forum with 6S on their lips and two 3S packs in their hands & a boat thats not doing what it was acclaimed to do.Land, Sea & Air, A true RC Addict.
A few thoughts here (waiting for 24 hr. cure epoxy to set on build so whatever). I think there's two types of 6S setups under discussion. The first is the " it goes fine on 4S; let's see what it'll do on 6S". No need to explain what'll happen there, although it helps to caution these people. The second is the well balanced setup as Simon describes, which has some distinct advantages. One advantage that seems to be brought up frequently is more runtime. But let's examine this blessing : I seem to pick up that the thinking is that a 6S 5000 mah 1P setup runs longer than a 4S2P with 2X 5000 (10K mah) on board. I'm not convinced of this. Apples to apples - with both setups running 2P, the 6S setup is carrying the extra weight of a 4S 5000 pack. In most cases this extra weight will make the boat slower. OK, it'll draw less current, go slower longer, and cost more. Is this really desired ?
I like oval racing. The P class in its various configurations represent a big share of the action. The 2012 FE Nat's will run 26 classes. Only 8 classes above P (divided between Q and T) are offered, two of which are offshore requiring a full load of cells. These Q and T boats are expensive ! The SC's longivity is frequently an issue, and keeping a few sets of batteries charging for each round gets pricey. For myself, and my racing budget , P class is all I'll do; not to mention that the last P & Q classes I saw run in sprint heats was a few years ago in AZ and there were only three boats there in those classes. ( Yes , SAWs are a different thing. Three guys - Mark, Tyler, and now Boyd had Q & T boats. Many problems abounded for these brave guys in the last and previous SAWs to say the least.)
All things being equal (where does this happen ?) I'd like to try a 6S setup someday. Until then, as they refer to me in Great Britian, I'll just be known as
"His Royal P-ness"
TonyLast edited by properchopper; 09-18-2011, 03:59 PM.2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
Uhh, hang on a minute.......Originally posted by LarrysDrifter View PostWell said, Royal P-ness!!
I run a 6s2p setup and it's great reliable setup. My whole reason for this thread is that a lot of new comers were coming in running 6s on setups that were not properly setup or meant to run 6s on i.e guys running 6s on cc1515 2200kv motors, there was a common mis-understanding that the only way to have a fast boat was to run 6s on everything... I have nothing against 6s + setups, its just a matter of the proper setup. Like Jim said about guys running 4s on the micro boats, some guys just really don't get the point and "speed" chasing out ways logic and proper decision making/reliable setups.
If you look i have been reading posts in this website like crazy! Im a newbie and would like to make my bj26 a fast reliable boat. After reading this post Im rethinking 6s... Thanks i guess? I was thinking it would be Easyer to make use of the erevo 3s 2p packs i will always have on hand. That was on rough water i can run 3s and on glass water i could run 6s. I asked what to run in my boat for 6s but nobody has given any advice. I guess i have more to learn! I want to do things right and that might mean getting some 2s packs just for my boat. This thread just might have saved another newb!...thanks guys if anybody has a recommend set for me pls let me knowLast edited by Stephavee; 02-14-2012, 04:20 PM." Do you really need anouther boat "
YEP!
This is a great thread, thanks Diesel and thanks for the KV chart.
Its true about the RC car runners with 3s batts. They get a Boat and they don't think of buying new batteries for the boat they use the 3s packs combined for 6s and sometimes they are very low C rating so they cook em
This KV chart could be useful on the homepage listed as for NewB's
A member recently bought the a 1520 off me to put in his Hor Rocket 25" Mono on 6s(as he only had 3s batts). I hope he re-enforces that hull...
A delta force 26" with 4074 2000kv and 4s is fast enough!Everything that has a beginning, has an End
All my boats run on 6s. For me, all I buy is 3s packs. Connect in series and put the throttle in rabbit mode. It comes down to simplicity as far as I go. As far as my land vehicles go, they run on 3s, so its a win win for me. But, I also know what kv to use with each.
I want to run 6s in my BJ26 "just for simplicity" also but how do you find what can size to get? leo 3674, 4074, 4082? delta or Y? a link to the right info or just solid advice would be helpfull!" Do you really need anouther boat "
YEP!
How fast do you want go, and what ESC will you be running?Originally posted by Stephavee View PostI want to run 6s in my BJ26 "just for simplicity" also but how do you find what can size to get? leo 3674, 4074, 4082? delta or Y? a link to the right info or just solid advice would be helpfull!
Go to www.leopardhobby.com for all the specs on their motors including what wind their motors are.
