Obsession with 6s
  • keithbradley
    • 3663
    #151
    Check out the TP power motors. A 4082 (or 4092 if you want to go overboard) would be an affordable option. They have vented endbells and tend to run cooler than the Leopard IME.
    It looked like a fairly sizable prop in the vid....645? s230? If it's something like that I would expect a cumulative heat build up in a 4074 on 4s. I bet a 4082 would knock a few degrees off. Combo that with the vented ends and it might make a big difference.
    I assume you've tried different timing settings...
    www.keithbradleyboats.com
    • Diesel6401
      Memento Vivere
      • 4203
      #152
      Was running a m445 on warm days and a m645 on cooler days. The m645 was hauling butt, but got hot and fast that was 15* timing. Then dropped down to 11.25 w/ a m445 and no issues which I would expect. The prop in the video is a x447/3 cut down to 42mm detoungued and cupped if I'm not mistaken. That was the first run w/ that prop. Boat liked it, motor not so much.
      Sent from my T-Mobile G2 using Tapatalk 2
      - Diesel's Youtube
      - Diesel's Fleet
      • keithbradley
        • 3663
        #153
        Wow, she has some bite for a 42mm prop!
        If you haven't tried it yet, drop the timing down to 5 deg or so and see what happens with the speed/temp. Sometimes the higher kv motors will pick up speed and efficiency at lower timing, even if they aren't D wind motors. Maybe not, but it doesn't hurt to try.
        • Alfa Spirit
          • 2131
          #154
          Originally posted by iamandrew View Post
          TO be honest, thats wrong with the spartan thats just blown up in the picture?
          I can see ALL its hardware still in it! thats got to be a good selling point
          Ive found higher RPM with smaller props = a lot better handling boat in general.
          Less snaking when under power, however the lead bearings do need to be replaced , or just go with speed master stuff
          I dont think traxxas got it right with the Spartan, but then again, its not like most people that own proboats or aquacrafts are running them in their stock config either.
          I' m agree, high RPM with small propellers is great, especially with twin setup.
          2 x Scorpion 3026 1900kV 6S on each motor
          • Diesel6401
            Memento Vivere
            • 4203
            #155
            Interesting on the timing and thanks for the explanation. I may try that as well. I may drop my 240 ice in it for data logging. My eagle tree is setup for 5.5s but im running 6.0s on this boat (battery connections)
            - Diesel's Youtube
            - Diesel's Fleet
            • drwayne
              • 2977
              #156
              Ive just read post #1 to end .. and originally this thread was about 4S rtr boats claimed capable of 6S .
              stock rtr 4S boats are problematic with 150% that voltage, a known issue of marketing to overenthusiastic newbs.
              Burn and learn ........
              However, re-configured they can well handle 6S, or more.. I recall a 4S genesis hull on 8(?)S at near 100mph recently, here on OSE...
              6S is not an offensive power to 1800Kv, if done correctly.
              Here is 6S to twin 1800Kv in a custom build
              Here is a quick vid of a single 6S pack to a pair of 1800Kv.
              cheers
              Wayne
