Well ya know, us florida crackers ain't got much o them technical minds to wrap round such equashuns
Turnigy Nano Tech is here!
Originally posted by sailr View PostMaybe I read it wrong. I thought he was saying the voltage was going to drop quicker. Still not sure why you would set the LVC that high.
I have experienced an issue once where I was drawing so many amps, the LVC didn't cut in right away and I got to about 2.7v per cell then it cut in all of a sudden..... Not sure if this is what the poster meant?
(kb45 1700kv with an X450 prop and 4s)
sounds like your LVC is wackedOriginally posted by crabstick View PostI have experienced an issue once where I was drawing so many amps, the LVC didn't cut in right away and I got to about 2.7v per cell then it cut in all of a sudden..... Not sure if this is what the poster meant?
(kb45 1700kv with an X450 prop and 4s).NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
hmmm, maybe! I've never experienced that. But with the higher C ratings, that should allow more amp draw and help prevent it I would think.Mini Cat Racing USA
www.minicatracingusa.com
Yeah, sounds more like a bad ESC than a battery problem.Mini Cat Racing USA
Originally posted by sailr View PostYeah, sounds more like a bad ESC than a battery problem.
agreed, and isnt that what its built to do?Originally posted by Rumdog View PostYep, also the only real reason the lvc would kick in early is if the cells can't [rovde the needed amps. Voltage drops, LVC kicks in.
ESC is still fine, and LVC cuts in nicely when im not trying to draw stupid amounts of amps from it... I just think on this particular occasion I drew too many amps, too quickly and the LVC didn't cut in right away.
sounds like a battery issue
the LVC is built to save the batteries and if its not keeping up its not working right!
Sorry.
What I was trying to say is that they will hold the voltage higher under load & that if the LVC is set to say 3.0 V They will totally discharge their full capacity & sometimes even more before the voltage drops to the LVC & you've over discharged your battery as there will not be around the 20 % capacity left.
Even when set at 3.2V my 40C packs will have only about 10% or 15% left if I let them hit the LVC (which I try never to let happen)
So these Higher rated Packs WILL hold their voltage Higher for longer & the packs Will most probably over discharge before they hit an LVC of 3.2v or maybe even 3.4V Remember over discharged is with less than 20% capacity left in the pack.
I've put back 5480mah back in a 40C 5000mah pack once when I ran it until it hit a 3.0V LVC. A 20C pack wouldn't allow that to happen.
as its voltage would sag earlier.
As a rule I try to bring the boat in before I hit any LVC.
Hope this helps a bit.
Paul.Last edited by 785boats; 06-29-2010, 02:29 PM.See the danger. THEN DO IT ANYWAY!!!
