Turnigy Nano Tech is here!
  • cybercrxt
    • 2926
    I was just about to order some 6 cell packs..I think I will now wait a few weeks to see how this pans out! Mike
    http://www.hobbycity.com/hobbyking/s...8&ParentCat=85
  • crabstick
    • 955
    Matt.
    www.rcboats.co.nz
    • LiPo Power
      DJI Drone Advanced Pilot
      • 3678
      holly crap.....
      Canada
      • crabstick
        • 955
        Just ordered... Hope they are as good as the label
        Matt.
        www.rcboats.co.nz
        • sailr
          • 7128
          They are just now catching up with the Hyperion G3's that have been out for several months now. Hyperions are more but available and warranteed here in the states.
          I give a great discount to the OSE guys.
          Mini Cat Racing USA
          www.minicatracingusa.com
            • 9481
            I just saw those Nano packs..
            what's the big difference with these new cells?
            • egneg
              • 4759
              I think they changed things a bit but they still list 4S/5000/45C packs for about $76.00.
              IMPBA 20481S D-12
              • crabstick
                • 955
                The Burst rating mainly
                Previously Turnigy was doing 40-50c cells, I have on order some 45-90c cells and some 35-70c cells.
                Hopefully this will mean less voltage sag under high load.
                Matt.
                www.rcboats.co.nz
                • Jesse J
                  scale FE enthusiast
                  • 7818
                  I didn't see batteries on your site??
                  "Look good doin' it"
                  See the fleet
                  • sailr
                    • 7128
                    They are not on our site. We will be stocking just the 3S 2100 25C's for use in our mini boats. All other batteries are special order. Just email what you need and we'll take it from there.
                    Mini Cat Racing USA
                    • 785boats
                      Wet Track Racing
                      • 3423
                      Probably need to set the LVC even higher now as they will most likely totally discharge their capacity before hitting 3.2-3.4 Volts. Gonna take some testing to still leave the recommended 20% capacity in the packs. That's if you drive by the LVC.
                      Cheers.
                      Paul.
                      • sailr
                        • 7128
                        Huh? Where did you get that logic? They hold their capacity even longer. Why do you think they would discharge more quickly and why would you think you need to set the LVC higher? That doesn't compute.
                        Mini Cat Racing USA
                        • Rumdog
                          • 6667
                          I think he's saying that the voltage won't lag as much under load, meaning that they may run longer before hitting the LVC. The only time I've had an issue with that happening is if the motor is pulling more amps than the packs can supply. Which def. shouldn't happen with packs rated like these, unless you're severely overpropped.
                          • sailr
                            • 7128
                            Maybe I read it wrong. I thought he was saying the voltage was going to drop quicker. Still not sure why you would set the LVC that high.
                            Mini Cat Racing USA
                              • 9481
                              that's how it reads to me to..
