32" Mono Build
  • ozzie-crawl
    • Sep 2008
    • 2865
    #61
    i have been using for the last couple of years a product called lanotec
    its made from the oil of sheeps wool. its used in high pressure industrial applications,its thick like grease but as soon as it gets a bit of tempreture thins out but doesnt spray every were, its water proof
    and stops rust. if you get a bit in side the hull from the stuffer tube just wipe it out and it doesnt stain like grease
    • andym
      More Go Than Show Prop Co
      • 2406
      #62
      Douggie would like it too as it is made of Lanolin the fat/oil from wool. Yes Douggie it does smell like an old Ewe. The Sydney water taxi fleet uses it as an anti fouling agent on their boats and have found it has reduced their fuel consumption after allot of coats by reduced drag. It appears to have a residue affect and builds up on the hulls. A lot safer for the marine environment compared to the modern anti fouling paints as well.
      • ozzie-crawl
        • Sep 2008
        • 2865
        #63
        its also used as a deodorant in n.z and tasmania
        • andym
          • 2406
          #64
          Ha Ha Ha Ha Ha Cop that young Paddy & Simon
          • crabstick
            • 954
            #65
            I use parrafin oil its a food grade lubricant. white chain and drive spray - by rocol.
            i use it on my flex as it clings like mad but doesn't sling.
            works good as my driveline's are normally like silk
            Matt.
            www.rcboats.co.nz
            • sailr
              • 6924
              #66
              sounds interesting. unfortunately a google search didn't turn up a source for it in the U.S.! I guess you aussies are protecting your sheep!
              Mini Cat Racing USA
              www.minicatracingusa.com
              • bustitup
                • 3071
                #67
                heres mine .. .187 flex and 3/16" prop shaft which is .187 also
                the round shaft end has a square in it that that square end of the flex slides into.....problem is with this system the flex assembly wont slice out the strut because of the design of the prop shaft so you have to take off the strut or pull the motor to grease your flex shaft
                Originally posted by Peter Zicha View Post
                Just out of curiosity can someone take a photo of one of these drives , I purposely use a .250 square end on all of my extreeme high powered setups at the strut with excellent results , is it the square drive or is it the fact that its just to small .
                Just curious guys please don't read anything negative into this................
                • sailr
                  • 6924
                  #68
                  your pic didn't come all the way through
                  Mini Cat Racing USA
                  • bustitup
                    • 3071
                    #69
                    issues with my connection...fixing it
                    • bustitup
                      • 3071
                      #70
                      fixed
                      wondering about using this system myself......the two posative points about this system is that you can never loosw a flex or prop shaft
                      and with the sliding square drive theres no worry of your drive dog being to tight against the strut
                      • sailr
                        • 6924
                        #71
                        1/4" is hefty. The square will hold up. Not on smaller shafts. I've spun off a few. Ended up changing out the strut and going to regular flexshaft.
                        Mini Cat Racing USA
                        • ozzie-crawl
                          • Sep 2008
                          • 2865
                          #72
                          thats one good thing about them you wont loose a prop if the coupler comes loose, but usally with this setup you run a small teflon washer between the dog and strut so the push from the prop is placed at the strut not the motor wich can change the characteristics of how the boat runs, this also means there isnt load on the rear motor bearing either.
                          • lincpimp
                            • Jul 2007
                            • 252
                            #73
                            Wow, tons of great info on the drive and hardware, thanks guys. Nate did include a std flexshaft with soldered prop shaft.
                            Looks like I have a little work to do on this bad boy. Seems like the cloth layer inside the boat has not been damaged, just the gel coat and whatever they used to make the strakes in the bottom of the boat, looks like just more resin, or gel coat, no actual glass fibers there... I will most likely use "kitty hair" short strand fiberglass mixed with resin and some polyester filler. Easy to work with, and it sets up strong!
                            Not going to be racing this boat, I just play with them in the local ponds...
                            I will start a thread when I get to the repair stage.
                            "These rocky mountains aren't very rocky!" "Yeah, that John Denver is full of S**t!"
                            • Punisher 67
                              Ignore list member #67
                              • 1481
                              #74
                              Nate if you still eventually want your mount here is the 4in / 5in combo 1527 mount you requested . If not someone else will eventually nab it so no biggy there either
                              • ozzie-crawl
                                • Sep 2008
                                • 2865
                                #75
                                i usally buy a hull then get all the parts needed to fit,but with the look of that motor mount it would be worth getting then finding a hull to wrap around it
