cat biuld
  • zanda
    • 136
    #91
    Originally posted by peells View Post
    Do you know the size of the cans on your motors? 36X56 you should get some kind of water cooling for them going on your esc's get 2 little computer fans for them and screw them right down on the cooling fins of the esc's and tap your power right off the connection on the esc board where the batteries come in at, we have found that a couple of 440 screws will fit the fin spacing, on other esc's but it works great if they are car type esc's which is what it looks like you are running, don't forget to use hatch tape you do not want any water getting in there esc's are expensive to be drowning.
    i dont understand what you are talking about with the 440 screws
    • peells
      • 716
      #92
      are they brushless? if so just switch two wires on one motor
      Peter Eells; Fun, and Helping others To Have Fun!!!
      RC.Boats.by.Pete@gmail.com
      • zanda
        • 136
        #93
        yer they are brushless . red blue and black . i just swap the red and the black correct ?
        • peells
          • 716
          #94
          any two on one motor
          • 6S HYDRO
            • 1320
            #95
            Hey zanda, you dont need another dx3.0 for cheap do you - pm me
            • zanda
              • 136
              #96
              almost there. put some small fans in position today and picked up a lipo.
              just need some cash to get some cooling 4 the motors and some props .
              i printed out the letters OSE and put it on the port hand side .hope no one minds
              • zanda
                • 136
                #97
                you can see the fans i have installed on the escs
                • peells
                  • 716
                  #98
                  I see you like Electronic Packing Material for Boat Stands too!! I glued a piece of 1/8" ply wood to the bottom and made two strips going across the top, the width of the tunnel, and the bottom makes a nice place to put an extra battery.
                  Ose will send you some stickers if you ask they look nice,
                  And Your boat looks nice as well, Take a video of the Madin Run you only get one!! your boat should really move out and handle very well, make sure you use the right and left cables (if you are using cables)
                  • 6S HYDRO
                    • 1320
                    #99
                    sorry but one 7.4 5000 is not gonna power 2 systems and fans do not work in sealed small areas, hence watercooling
                    • zanda
                      • 136
                      #100
                      what do u suggest then 4 a battery set up ? the fans where installed as i carnt get the esc water cooled . i understand its a small air tight area but it better than nothing.
                      • peells
                        • 716
                        #101
                        The fans will help I know this for a fact I use one on my big boat and it works! you are running your batteries in parallel right? and you are using 2 of them correct? they do look a little small but if you had 4 of them since you already have 2 you could wire them up for 4s2p (taking two of them and wiring them in series then take the other 2 and do the same thing) and make 2 packs running them in parallel and then you would have plenty of power as long as your esc's could hack 4s as I do not know what Amp rating they are
                        • 6S HYDRO
                          • 1320
                          #102
                          they will work in big boats, i said in small sealed areas- like this boat. what do you mean you cant watercool the esc's- they have heat sinks on them dont they. just get or buils a cooling plate foe each esc. and for the batteries those are 1 5000 mah 7.2 2s2p with 2500 mah per side parralelled together for 5000 mah. you will need 2 of those setups one for each esc- and thats not much power. i would at least want a 3cell for each esc-boats dont run very fast until theryr on 4s, but a twin drive 3s per side should be very nice. it would be similar to the new king of shaves 34" brushless setup
                          • peells
                            • 716
                            #103
                            Well has it seen the water yet?
                            • zanda
                              • 136
                              #104
                              just need to get the money together to get the 2nd battery and props . im currently unemployed. dam ressesion. so money is tight
                              • peells
                                • 716
                                #105
                                How about that video
