Warning: Trying to access array offset on null in phar://.../vb/vb.phar/bbcode/url.php on line 2 Warning: Trying to access array offset on null in phar://.../vb/vb.phar/bbcode/url.php on line 2 cat biuld - RcBoaters Forum
cat biuld
  • zanda
    • 139
    #106
    can anyone interpret this ? i think its japanies.
    also im having major problems up loading to youtube . its only 30sec of footage anyone else having problems?
    • peells
      • 739
      #107
      Originally posted by zanda View Post
      i dont understand what you are talking about with the 440 screws
      4-40 screws I get them from our local hobby shop, I think they are close to a 3mm -3.5mm size (diameter) which is about the spacing on your cooling fins on your esc's (yours look like Novak GTB brushless setups without the fans I hope this helps.
      Peter Eells; Fun, and Helping others To Have Fun!!!
      http://rcboatsbypetere.blogspot.com/
      RC.Boats.by.Pete@gmail.com
      • zanda
        • 139
        #108
        what about 2 of theses peells?
        http://www.hobbyking.com/hobbycity/s...hless_Boat_ESC
        • zanda
          • 139
          #109
          any chance peells you could direct me to which props on ose i should get as i need a left and right as you would no . got your email and i think i should get a set of octura x438 and the x430 what are your thoughts. if you could email me or on this page would apreciate it
          thanks
          • peells
            • 739
            #110
            that looks fine but make sure you have an account set up there first so it saves you money, look at the top bar where it asks you to sign in there is an account set up button there.
            • peells
              • 739
              #111
              http://www.offshoreelectrics.com/pro...prod=oct-x430r
              http://www.offshoreelectrics.com/products.php?cat=86
              the second prop down is the x430
              The x430 and the x442 are the smallest sizes they offer here and make sure you get the prop shafts which will let you mount them to your boat, the x430 is for an 1/8" shaft, we use the .130 cable with the 3/16" shaft turned down for 1/8" props but you have to buy the right hand cable with a 3/16" prop shaft as OSE does not offer just cable and then you have to buy a separate shaft to match the 3/16" x 1/8" shaft if you go that way
              http://www.offshoreelectrics.com/pro...prod=oct-oc4pn
              http://www.offshoreelectrics.com/pro...od=oct-oc64pkg
              http://www.offshoreelectrics.com/pro...oct-oc130R-24c
              This is what I was talking about the link above is why you would need to buy the extra shaft, drive dog and prop nut,
              we assemble them our selves using sleeve retainer (it is a liquid like glue) available at automotive parts stores. I hope this has been helpful for you and others.
              • zanda
                • 139
                #112
                i have finally got a job . it has only taken 3mounths... so i will have money to finish of this kitty
                • reaper racing
                  • Aug 2009
                  • 21
                  #113
                  hey zanda, u are in sydney right? i will be there this weekend maybe with my hydro or cat, (unsure which yet) if ya have that thing wet by then maybe find the time to run together?
                  • peells
                    • 739
                    #114
                    Good for you I know how nerve racking it can be looking for work!!
                    • zanda
                      • 139
                      #115
                      sounds like a plan dont think it will be running , but i can get my mini c gone brushless out for a blat. i will pm you my mob. where in syd will you be ?
                      • peells
                        • 739
                        #116
                        ok so what has changed on your boat lately (Besides gathering dust like mine)
                        • zanda
                          • 139
                          #117
                          not much mate . i got the props turns out they are the wrong size
                          • peells
                            • 739
                            #118
                            So did they send the wrong size? or did I give you the wrong info? I hope it was not me.
                            So how close is your boat to getting wet? I have mine real close just needs the details a little cleaned up and clear coated then final assembly and we will be wet with a video.
                            • peells
                              • 739
                              #119
                              LYNX (BobKat's Evil Twin) that is the name on my thread
                              • zanda
                                • 139
                                #120
                                my drive shaft is to big for the props : (
                                what do u think open up the prop holes a little and make it work? . i think i will hold onto them for another biuld.
                                all i need to do is get the props and 2 speed controlers which is the easy part,also need to water cool the motors wich i have worked out that will be hard job.
                                news up date i have been bashing around my new e-revo vxl on twin 1800mah 2cell 7.4v this little care hit 110kms over 100m dist dam thing should have wings.
