Maritimo build
  • bonewar
    • 587
    #256
    Top speed for the Simrad Cat so far is 64.5 mph / 103.8 klm/h.
    This is with a set of octura x442 s/b cupped.
    So with the new 30c thunder power lipos and the new ABC props , should be very interesting.
    I will keep you informed how those ABC props turn out .
    Bonewar
    • egneg
      • 4759
      #257
      Originally posted by wolf IV View Post
      I told egneg to just do some 442's w/ +2/ deg extra. No cutting..? Just wanna see what happens... But then i also asked him what he thought and he hasnt got back to me yet..
      I replied to your reply ...
      IMPBA 20481S D-12
      • Fruity
        • Jan 2009
        • 189
        #258
        447's?
        Wolf,
        just curious, why not run the 447's, will it pull too many amps?
        Cheers...Tim.
        The reason I ask is we are about to start testing my friends twin cat - 1.1 mts with twin 1515 1Y's running 5S, we have been recommended 442"s to start with and 447's. ESC's are Castle 240's.
        The 1515 1.5Y on 5S has very similar RPM to the 1515 1.5D's on 4S, so prop speeds will be very close to what you are acheiving.
        Thanks....Tim.
        • wolf IV
          • 1050
          #259
          Originally posted by Fruity View Post
          Wolf,
          Cheers...Tim.
          Thanks....Tim.
          .MY BOAT WEIGHS ALOT FOR THE HIGH RPM MOTORS AND SHE PULLS ALOT OF AMPS. IM RUNNING THE HI MODEL ESC'S AND T
          HEIR PROBABLY NOT AS EFFICIENT AS THE 240'S ( BUT CHEAPER).. 447'S WILL BE TOO MUCH TO RUN THROUGH A SET OF LIPOS. WOULD WORK AS A SAW SET UP BUT SPEEDS WOULDNT BE MUCH OVER MID 70 MPH IM GUESSING AND IM NOT DOING THE SAWS JUST TRYING TO SQUEEZE IN AT 70 MPH. ( PERSONAL GOAL)
          http://www.youtube.com/watch?v=e-npTLBHefY
          • wolf IV
            • 1050
            #260
            Originally posted by bonewar View Post
            Wolf,
            Ok tell us what are these new props you talk of.
            Bonewar
            BONEWAR ,WELL THIS IS WHAT CHUCK THINKS WILL WORK, HE KNOWS BEST!! LOOKING FORWARD TO GETTING THEM! THIS IS AN EMAIL FROM CHUCK TODAY : "I was thinking that I would still detongue them a bit to increase the overall pitch and cup them a bit to narrow the thrust cone along with the added 2 degrees. Who does this sound to you?"
            • bonewar
              • 587
              #261
              Wolf,
              That sounds very good. I think you will get there with these props. You know the drill mate , Couple of laps check temps , speed , Good luck dude .
              Can you video the run for us , I love watching that Timo off yours scream across the water.
              Also if they don't do the job maybe these ABC props I'm trying will do it.
              I'll keep you informed what happens with them.
              Bonewar
              • wolf IV
                • 1050
                #262
                Originally posted by Jeff Wohlt View Post
                Hey man...hope you are feeling better. Can you tell me what the length of the shafts I made you are from the 6mm point to the 3/16" I have another set to build and do not have the stingers.
                Looking very nice!
                Jeff what's up buddy! I took some time off f.e due to finances but things are looking up again :) could you make me (X12) The 6mm part end to end is (2.514'') and 3/16 is (1.05'') drives? Ill put em together just need the shafts.
                • wolf IV
                  • 1050
                  #263
                  Mr. Egneg! If your still doing props I could use a few :) Gett'n her wet again!! (X2 r/h s/b 442's w/ +2/ deg extra. and x2 l/h match)
                  (X2 r/h s/b detounged 442's no cup and back cut and x2 l/h match set) and (x2 r/h 447 s/b detounged 447's and x2 l/h match set) so that's 12 props in total r/h and l/h match sets. pm me the price and lead time. Thanks!!!!!
