Hydro & Marine 50" mono Build
  • Gerwin Brommer
    • Dec 2008
    • 928
    Here we go (slow)
    Hydro&Marine Xray, the large version.
    Motor : Plettenberg 370/50 BM
    Esc : Schulze 40/160
    Hardware : MHZ Z-drive type1 , with gear build-in.
    Juice : Kokam 4000 30C H5 10S2P
    First of all : the hull is thin, I can almost read the newspaper with the hull on top of it
    So : reinforcements are needed.
    Step 1 : transom , it's not a flat one, so plywood is glued in the center,
    left and right from the ply : Styrodur C (Roofmate)
    Step 2 : the "hips" , next to the hatch , also very thin, I wouldn't take the risk of cracking the hull when a flip-over happens.
    So the hips are filled with roofmate aswell.
    Covered with glasscloth ofcourse.
    Step 3 : Front-upperdeck : same story. On the pic is the strip of Roofmate that is placed under the nose. Covered with glasscloth.
  • EPower
    • 417
    Go Gerwin can you put a picture of the boat with the hatch on,is the Z drive like a stern leg type i will be keeping a look on this build Cheers
    Adrian
    • Gerwin Brommer
      • Dec 2008
      • 928
      Adrian :
      The Z-drive : http://www.mhz-powerboats.com/shop/artikel2190.htm
      • Fruity
        • Jan 2009
        • 189
        Gerwin,
        MHZ make some beatiful equipment, I have used an S6 drive on a Gas boat, but I don't know who has worked out their imperial to metric conversions:
        1729/N Z-Antrieb - Alu-poliert
        Länge (length): 175 mm (4.5 inch) 175mm = 6.8 inches
        Höhe (height): 150 mm (4.1 inch) 150mm = 5.9 inches
        Gewicht (weight): 695 g (7.9 oz) ?? I am unsure if this is correct?
        Welle (Prop Shaft): 6,35 mm (1/4``) Correct
        max Prop (max prop): 72 mm
        Cheers....Tim. PS, your build look good I will be eagerly awaiting updates.
        • Punisher 67
          Ignore list member #67
          • 1616
          Hope you don't mind if I tag along for this build.................................
          • Steven Vaccaro
            Administrator
            • 8932
            Me too....
            Steven Vaccaro
            • Gerwin Brommer
              • Dec 2008
              • 928
              Peter & Steven,
              You can start ordering a truckload of popcorn, cause I'm a very slow builder
              • Gerwin Brommer
                • Dec 2008
                • 928
                Yesterday I got the Zdrive back (was sent away for an upgrade)
                so the build continous :
                Marking the holes, drill'em, and mount the drive.
                • Gerwin Brommer
                  • Dec 2008
                  • 928
                  overall shot :
                  • H2OCamel
                    FAST ELECTRIC EVERYTHING
                    • 494
                    Me too....
                    Me three for tagging along!
                    "Discussion is an exchange of knowledge; an argument, an exchange of ignorance." Robert Quillen
                    • H2OCamel
                      • 494
                      Looking very good too!
                      • z400
                        • 1333
                        Should be an amazing boat!
                        Cant wait to see more!
                        Z
                        KBB34" Mono - Fast
                        ToySport Triton- Not as fast
                        • Punisher 67
                          • 1616
                          Me and orville are great friends Gerwin , Steve probably knows him also , the three of us will watch your build .....................http://www.orville.com/index.jsp
                          • Gerwin Brommer
                            • Dec 2008
                            • 928
                            little update.
                            Mountingholes for Zdrive.
                            I drilled the holes for the bolts a few mm larger.
                            On the picture you see : bolt, aluminium tube, stainless steel tube.
                            Alu tube goes around the bolt.
                            SS tube goes over the alu tube.
                            The alu keep the ss tube centered.
                            Then the tube is glued in the hull.
                            It keeps oil and water away from the ply that is glued in the back of the boat.
                            And : if I want to change the position of the drive a bit, I can remove the alu inserts. That gives me about 1mm up and 1mm down, room for play.
                            The smaller holes have brass tubes inside.
                            • Flying Scotsman
                              Fast Electric Adict!
                              • 5195
                              Gerwin, as usual it looks like crap Come on you Dutch twit it is time to speed up the build process Too many Bokma Jonge Graanjenever ??
                              Douggie the kind one
