Delta Force Vortex Hydro 34 projeck gone wrong
    • 9438
    Sorry, been in a lot of pain lately.
    The .130 cable is iffy for strength imo. It's worth a try since you have it.
    If you decide to try it I would mount the motors more forward. Components need to be laid out and latr installed so the center of gravity is approx an inch or three behind the sponsons...
    what struts did you order since the strut Inner diameter may not match your stuffing tubes? Are you using Teflon inner liner?
    • ErickTheBold
      • May 2020
      • 20
      haven't ordered them yet as not sure what I need and I forgot
      • TRUCKPULL
        • 2971
        What are you using for a turn Fin?
        Larry
          • 9438
          Has no fin. If he does a twin and only does saw's no real need. IF he wants to turn well he needs one.
          Glad you forgot Erick!
          what is brass tube diameter?
          • ErickTheBold
            • May 2020
            • 20
            It's a 1/4 inch OD now but will need to replace it with a longer one so can change it to a different bigger one and add a bigger flex cable too.
            What turn fin should I get?
            I order all from offshore
            • ErickTheBold
              • May 2020
              • 20
              Also what flex tube size and tubbing will be best for my set up?
              • TRUCKPULL
                • 2971
                https://forums.offshoreelectrics.com...-s-and-Riggers
                Post #3 is the last one and most resent design
                MP me if interested.
                Larry Jaques
                  • 9438
                  If you use 1/4" OD tubing it can handle both 0.150" cable or 3/16" flex cables. Your choice either will work. You will need new couplers as well.
                  Speedmaster struts are 1/4" ID so the match up best. TFL struts are metric.
                    • 9438
                    • ErickTheBold
                      • May 2020
                      • 20
                      thanks
