Delta Force Vortex Hydro 34 projeck gone wrong
  • ErickTheBold
    • May 2020
    • 20
    Hello group,
    I built a Delta Force Vortex Hydro 34 with the following items, but it wont go very fast, ( not even close to planing).
    I would like some advise to what I did wrong.
    Note: it's only got one motor on it, but I bought gear for running twom motors.
    Hydro parts list
    Part Name Product ID: Notes
    Delta Force Vortex Hydro 34 df-vortex-34 Bare Hull (33.75" 857mm)
    CNC Prop cnc-4014251 40mm - 3/16" bore
    CNC Prop cnc-4014251-R 40mm Reversed - 3/16" bore
    K&S Stainless Tubing ks-stainless-tb-12 12" long (305mm)
    Speedmaster Dual Pickup Tapered Rudder Assembly ros-spdr-011a
    K&S Brass Tubing ks-brass-tb-12 12" long (305mm)
    Leopard 3650 Motor leo-3650
    Radiolink R7FG 7 Channels RC Gyro Receiver, R7FG 7 Voltage Telemetry Long Range Control, Water-Splash Proof for RC Crawler Drifting Car, Boat, Works for 2.4Gh Radio Controller RC8X RC4GS RC6GS V2 V3/T8S/T8FB
    Radiolink RC Transmitter and Gyro Receiver RC6GS V3 R7FG, Voltage Telemetry, 30 Models Storage 2.4Ghz Surface Remote Radio Controller for RC Crawler, Drifting, Bash, Buggy Cars and Boats
    Hobbywing SeaKing 180A-V3 Brushless Marine ESC Waterproof Speed Control
    ANNIMOS 20KG Digital Servo High Torque Full Metal Gear Waterproof for RC Model DIY, DS3218MG,Control Angle 270?
    Zeee 11.1V 3S Lipo Battery 100C 9000mAh Deans Connector Soft Case Battery with Metal Plates for RC Car Truck Tank Racing Hobby Models
    thanks in advance for any tips or help in getting it right.
    Erick the Bold
    Motor kv????
    • ErickTheBold
      • May 2020
      • 20
      motor KV ?
      don't know more tham Leopard 3650 Motor leo-3650
        It should have markings on it for it's wind/KV/rpm
        Look at this picture>> https://www.offshoreelectrics.com/pr...?prod=leo-3650
        • ErickTheBold
          • May 2020
          • 20
          LBP3650 3900kv
          • ErickTheBold
            • May 2020
            • 20
            see attached picture of motor
              So, you tried just one motor so far? ANy pictures of it rigged up?
              • ErickTheBold
                • May 2020
                • 20
                set up pics
                Heres some pics of set up
                Thank you for looking n helping
                  That says a 1000 words!
                  I am a bit busy this minute but I hav lots to advise on this...
                  I will try to answer asap... hang in there
                  • ErickTheBold
                    • May 2020
                    • 20
                    Thanks no hurry
                    I am on disablity and have all the time in the world
                    • ErickTheBold
                      • May 2020
                      • 20
                      Any help please
                      • Peter A
                        • 1624
                        4082 motor around 1600 kv, run 6s, change the solid shaft for a flex shaft and adjustable strut, prop 45mm.
                          Sorry, I'm an aging paraplegic that forgets from tim to time..
                          Although it looks better than some of my early builds there are numerous things to bring to attention.
                          1. solid shafts are more for scale boats not so much for the Ferrari you put it in. flex shafts are the rule these days because they are adjustable.
                          2. KV is high for a single in that hull, dual motors as you said you have them could get by on 2- 3S per motor. I'm not familiar on dual motor sport hydros. I've done a dual cat, not much different except the turn fin. YOu didn't show yours so maybe you don't have one that's o.k. for now, no worris...
                          3. I'm curious what is under whatever you used to insulate your connector joints??
                          You can get this to go fast with what you have mostly but I suggest new drive lines with flex cables and adjustable struts.
                          If you wanted to do a single drive, I suggest a larger motor with lower KV about half of 3900KV and run on 4s- 6s.
                          • ErickTheBold
                            • May 2020
                            • 20
                            here's what I have already
                            Product ID: ose-cable-130R
                            OSE .130 reversed (right) cable with 3/16" prop shaft
                            Product ID: ose-cable-130L
                            OSE .130 cable with 3/16" prop shaft
                            Product ID: ks-brass-tb-12
                            K&S Brass Tubing 12" long (305mm)
                            Product ID: cnc-4014251
                            CNC Prop 40mm - 3/16" bore
                            Product ID: cnc-4014251-R
                            CNC Prop 40mm Reversed - 3/16" bore
                            ordering the 45mm props
                            and two adjustable struts
                            Anytghing else?
                            • ErickTheBold
                              • May 2020
                              • 20
                              And two flex shafts
