Mhz mystic 114 build
    • 4340
    #106
    Originally posted by PlayerUnknown069 View Post
    Who makes the best collets? My left motor keeps burn shafts no matter how tight I crank it. The threads come loose. I even tried the OSE reverse collet with no luck.
    If you slip a cable, both the cable and collet go in the trash. Both have lost material at the mating point and won't hold with a new counterpart. Reverse thread collets aren't necessary. I too am migrating towards the machine collets on my high RPM builds. Regular TFL stainless 1/4" collets have always been a favorite of mine on my bigger boats, as were the old MBP collets. If I had room, I used the MBP collets on nearly all of my boats. The H&M and LMT style collets have slipped on every 1/4" cable I used them on. Didn't have problems with the 3/16" variety, but I don't trust them anymore.
      • 4340
      #107
      Originally posted by BUMBLESPECIMOODA View Post
      I hope I never have to find out how strong it will be...
      It is ready for deck, but I will be fitting out the components, pouring foam, etc, before that.
      [ATTACH=CONFIG]178985[/ATTACH] [ATTACH=CONFIG]178986[/ATTACH]
      Wow, that part dropped in there like a lego brick. Well done!
      6 cartwheels, 3 of which are on dry land, at 100mph will tell you how strong the hull is. Ask me how I know...
      • BUMBLESPECIMOODA
        • Feb 2023
        • 257
        #108
        Originally posted by Dirk Jan View Post
        I use the Ali Express versions too. I wasn't sure about the forum policy, posting a link to them.
        I didn't even think about that. Sorry if I did wrong. I will correct if needed...
        LOL. At the response of course, not your poor boat.
        • BUMBLESPECIMOODA
          • Feb 2023
          • 257
          #109
          @ PlayerUnknown069
          96mph... WOW.
          • PlayerUnknown069
            • Apr 2023
            • 72
            #110
            @ PlayerUnknown069
            96mph... WOW.
            Thanks, I think she has 100 in there with some balancing. You are next, your hull is going to be bulletproof. I do love the way it rides flat on the water.
            • PlayerUnknown069
              • Apr 2023
              • 72
              #111
              Do you know where to get spare shafts other than MHZ? They sell the set for $93 euros. They are an odd size, 6mm prop shaft to a 3/16 flex.
                • 4340
                #112
                They sell just the propshafts for less. You can glue in your own flex cables with loctite.
                • PlayerUnknown069
                  • Apr 2023
                  • 72
                  #113
                  Is it possible to unglue the flex shaft with heat and reuse the prop shaft?
                  • BUMBLESPECIMOODA
                    • Feb 2023
                    • 257
                    #114
                    Yes. I graphite epoxy my cables in place, and a bit of flame and they pull right out. Same as if you silver braze them in.
                    • BUMBLESPECIMOODA
                      • Feb 2023
                      • 257
                      #115
                      Feet
                      Rather than bond the flat plates into the hull, then build up reinforcement at their bases, I do it all on the part, then simply bond the parts in place. It turns out very clean with this method.
                      Here is the radio plate ready, with Shimano Dura-ace cable housing ends inside. Of course, I'll be using Dura-ace opti-slick cables and housing, cuz that's just the way I roll...
                      And the motor bulkheads starting:
                      The motor bulkheads will be very diffrent from the norm...
                        • 4340
                        #116
                        What did you build-up the feet of the servo mount with?
                        • PlayerUnknown069
                          • Apr 2023
                          • 72
                          #117
                          Beautiful build, I wish I had your Carbon skills.
                          If interested, I order these custom cnc collets. I am hoping these are the buy once and end all solution for me. Building shafts isn’t cheap, 85 euros for just the stubs from MHZ. I hope I never burn up a shaft and collet again.
                          • BUMBLESPECIMOODA
                            • Feb 2023
                            • 257
                            #118
                            I lay-up 2-layers of 6oz. carbon cloth on the area to have something mounted to it (see above post, where I laid the carbon on the packing tape). Same with the servo tray. Then I make a fillet between the plate and the lay-up "foot". Then more layers of carbon, to join the foot to the plate.
                            The motor bulhead will get 4-layers of 6oz. cloth, on both sides of the plate, with the balsa core between. A solid carbon plate will go into the balsa plate, between the 4-layer-skins, so that fasteners won't mash the core. And also to... :)
                            [ATTACH=CONFIG]179026[/ATTACH]
                            Those look the business! If mine slip, I'll be looking at those for sure. I'll be filling the ends of my cables with silver braze / mapp-gas as well, to help with strength.
                            • PlayerUnknown069
                              • Apr 2023
                              • 72
                              #119
                              To add, the collet has a replaceable insert which is what sold me on them. I’ll just have spare inserts.
                              • BUMBLESPECIMOODA
                                • Feb 2023
                                • 257
                                #120
                                Radio-tray installed. Bit of mud on the feet, mush-down in place, wipe up squeezed out mud. Done. There is plenty of realestate on the aft plate for electronics. I might cut off some, that is not needed.
