DIY twin motor mono build 'G-Force'
  • Dirk Jan
    • 167
    Hi fellow boaters,
    Last year I built a 32" Wildthing that I slightly modified. It started as a 60+ mph boat build, but it proved to be quite a bit faster with 75mph top speed.
    I enjoyed the build and performance so much, that I decided to build a twin mono. It is again based on the Wildthing, but I modified the design a lot. This boat is 33.5" and will get dual stinger drives and a 6S setup. Most likely 2x 3674 2000kV motors and 150A Flycolor esc's.
    Here's the design, although it still had a single motor setup here:
    I cut the frames and set them up at the building board.
    I also upload the build on YouTube, if you are interested:
    Next step is apply the bottom and side sheeting and release the hull from the build board.
  • Bande1
    • Mar 2023
    • 678
    watched the video this morning. will stay tuned.
      Yep, I'm subbed. Nice builds!
      • Dirk Jan
        • 167
        Thanks guys!
        Here's part 2 of the build:
        [MEDIA=youtube]mxPtTZE4NVQ[/MEDIA]
        I progressed a bit more after that. Here are some photos of the 200gr/m2 carbon weave I laminated into the hull.
        I put fillets of thickened epoxy (with micro balloons) in every corner.
        By using paper templates, I cut the patterns of each weave to size.
        All together quite a fiddly process. The hull feels very strong already.
        I will also laminate the longitudinal bulkheads with carbon fiber.
          • 4338
          Very nice
          • Notoriousone
            • Oct 2022
            • 69
            Clean work, looks great
            • Dirk Jan
              • 167
              Thanks guys. I continued the carbon laminate on the longitudinal bulkheads and the deck plates.
              The deck is just attached by tape for now.
              I got 2 Rocket 3670 1850kV motors and 2 Flycolor 150A esc's.
              I'm also working on DIY stinger drives. The stinger tube will finally be made from carbon tube.
              • sammyha
                • Jul 2018
                • 1038
                Very cool build! Love all the DIY components...
                Sent from my SM-G950U1 using Tapatalk
                • Dirk Jan
                  • 167
                  Thank you Sam [emoji41]
                  Here's build video part 3:
                  • Notoriousone
                    • Oct 2022
                    • 69
                    Besides the boat itself, I like your build videos, they’re fun to watch because of the fast pacing and good editing.. I like seeing precision work being done, I’m subscribed
                    • Dirk Jan
                      • 167
                      Thank you Notorious, I appreciate that!
                      • Dirk Jan
                        • 167
                        I filled the bow with pool noodle and I cut the deck opening. The deck is not attached yet.
                        I'm now working on the twin motor mount:
                        I modified the Flycolor 150A/ OSE 150A esc For a more efficient cooling and smaller dimensions, to fit this hull.
                        • Dirk Jan
                          • 167
                          I put some effort in making my own stinger drive from scratch. Why? Because I love DIY building [emoji41]
                          Here's the video of how I made it:
                          • Dirk Jan
                            • 167
                            Here's part 5 of the build:
                            The sides are glued and laminated to the hull, flotation is added, the motor bracket is made and the deck is fitted with the hatch support.
                            • fotis zzr
                              • Jan 2023
                              • 17
                              Respect to this guy. Love his DIY skills
