DIY twin motor mono build 'G-Force'
  • Dirk Jan
    • 167
    Thanks Fotis [emoji106]
    In the meantime I glued the deck to the hull and I glassed it with a double weave. I also installed one of the two drivelines:
    • Dirk Jan
      • 167
      Next update, I made the lipo tray from carbon fiber. I made my own carbon plate. It's a fun and easy process, explained in my video:
      • Dirk Jan
        • 167
        Next episode, no 7: I worked on the hull bottom, adding spray rails. Also I glued the lipo tray in the hull:
        • Dirk Jan
          • 167
          Last week I made a rudder bracket from forged carbon fiber.
          I made a mold from wood and taped it to prevent the carbon and epoxy mix to stick to it.
          The mold has a top part, which presses the carbon and epoxy together.
          The part came out nicely. After making some cutouts and a lot of sanding, this is how the part turned out:
          I will edit and upload the video of the process this week.
          • Panther6834
            • Apr 2020
            • 708
            Looks absolutely fantastic. Just remember that forever CF is never as strong as sheets. A good comparison/example would be the Zeus decks from Ownboard (electric skateboards, in case you didn't know). They offer decks made from sheet, and forged decks. Physically, both have 100% identical external dimensions. Whereas the sheet decks are hollow, with a honeycomb inside, the forged decks are (from what I understand) 'solid'.
            Even as thick as the forged decks are, they've proven to not be as strong as the sheet decks, and several have snapped...some somewhere in the midsection, others close to the rear of the front truck or the front of the rear truck. Granted, the rudder bracket won't see as much 'force' as standing on a skateboard...but, at the same time, the bracket is considerably thinner than the skateboard deck. As gorgeous as your bracket is, I really hope it does hold up.
            ~ More peace, love, laughter, & kindness would make the world a MUCH better place
            • Dirk Jan
              • 167
              Thanks Panther, for the detailed feedback. I'm curious about the strength too. This bracket is quite long, so I'm a bit concerned on the impact on the bracket and transom, when I crash the boat. I'm thinking on using plastic bolts to mount it to the transom to prevent big damage. I rather want it to break off, than rip the bracket or transom apart. Hopefully it will stay attached with the steering rod.
              It's an experiment all together. Let's see how it holds up. My Wildthing used to have a wooden rudder bracket (glass laminated), which lasted surprisingly long.
              • Panther6834
                • Apr 2020
                • 708
                I can see that. Some wood can be quite hard & strong...for example, cherry, and walnut.
                • Dirk Jan
                  • 167
                  Here's the video of the entire process, from mold making to finished product:
                  • Dirk Jan
                    • 167
                    I made good progress with the build. I installed both esc's, reinforced the lipo tray, made a servo mount and modified the hatch for the gps signal.
                    Here's video part 8:
                    • Dirk Jan
                      • 167
                      The G-Force had it's maiden run this weekend.
                      I ran 2x 2 lipo's and the boat handled pretty good. It has a little bounce and it spins out in tight corners, but I will work on that for the next run.
                      I got 62 ad 64mph on the runs. It's a good baseline, from where I will work on increasing the speed.
                      The Speed goal is 87.5mph (140km/h) so the tuning journey starts now.
                      • BUMBLESPECIMOODA
                        • Feb 2023
                        • 257
                        Sure is a pointy boat.
                        • Panchothedog
                          • Oct 2015
                          • 173
                          After watching your video, for a 1st run fanastic. Very well done. You might need a bigger pond to run in to hit 140 kph.
                          • Dirk Jan
                            • 167
                            Thank you. The pond is quite big; if I stand in the middle I can use the part near the big building too. I got 123km/h there with my Wildthing, so I have good hope I can push the speed a bit more over there [emoji41]
                            • Dirk Jan
                              • 167
                              I made some improvements on the G-Force.
                              I added a brace to the rudder arm, and I sharpened and balanced the props.
                              I can't wait to take her out again and set some speed numbers. Here's the video of the modifications:
                              https://youtu.be/K1tKlTvbvL0
                                I can appreciate your builds and videos. I used to do scratch building like this before the internet and world market for all things RC or electronic. Now I usually buy a hull or a wood kit and build them up.
                                The amount of work to do this is staggering and I salute you my friend of the Nederlands. Orange would look great, there is a nice orange color by VW, the code is not handy at this time however... Thanks for sharing, I look forward to future post and videos.
