An other "P" Sport on the table.
  • TRUCKPULL
    • 2971
    #61
    Been working on some 8mm "T" connectors the last couple of days.
    https://forums.offshoreelectrics.com...dering-T-plugs
    Got my Titanium turn fin mounted, with my new mount.
    https://forums.offshoreelectrics.com...-s-and-Riggers
    Now I to get to make one of my new cowls for this one.
    https://forums.offshoreelectrics.com...hp?60814-Cowls
    Larry
    • TRUCKPULL
      • 2971
      #62
      I finally got my plugs figured out.
      Larry
      • TRUCKPULL
        • 2971
        #63
        I finally got my single work bench cleared up, so I can layup my cowl.
        First picture is of my mould, all waxed up and ready to go.
        The last two are with two layers of cloth, (1/16" thick when finished)
        I will be ready to pull it Wed. morning.
        Larry
        • TRUCKPULL
          • 2971
          #64
          Cowl came out fine, I used lots of wax.
          second pic. - I use a dark masking tape to mark the outside of the cowl position. I also put a PEN line on the tape for center.
          Third pic. - Line the cowl up on the center lines, and position it front to back there you want it.
          Fourth pic. - Use a fine black magic marker to mark the cut out on the cowl, leave a little extra for sanding for your final fit.
          Larry
          • TRUCKPULL
            • 2971
            #65
            Cowl all cut and sanded to fit.
            I added some flotation to it just in case.
            Boat is all ready for a water test, hopefully tomorrow.
            If everything is Ok, Then I will put some stripping on the boat and paint and a windshield on the cowl.
            Larry
              • 9438
              #66
              Very Nice LArry. Can you tell me how long your nose piece is?
              Thx.
              • TRUCKPULL
                • 2971
                #67
                Thx.
                Hello Ray
                It is made of Balsa wood. It is intended for the front edge of a Plane wing. (like a half round)
                front to back - 3/4" Hight at the mounting surface - 1".
                The top and bottom edge are very ease to blend with the top and bottom decks.
                I put as much of thinned epoxy on it as I can to harder it up.
                I then add two layers of very light fiberglass cloth.
                Larry
                  • 9438
                  #68
                  O.k. thanks. I'll break out the balsa then.
                  SO it's 1" long or 1"high if it were standing on a table and the 3/4" is the dimension that mates up to the front bulkhead?
                  • TRUCKPULL
                    • 2971
                    #69
                    The flat side is 1' high.
                    The tip of the round, sticks out 3/4"
                    Larry
                      • 9438
                      #70
                      Interesting considering I'm dealing with 7/8" not 1". I wonder where 1/8" went? Maybe sanding the front bulkhead on the profile angle?? Anyway, thank you!
                      • TRUCKPULL
                        • 2971
                        #71
                        I install it so that there is 1/16" extra on the top and the bottom, and sand it off to match the top and bottom latter.
                        Larry
                          • 9438
                          #72
                          OOhhh, ok, that's that Cadbury secret. Thank you!
                          • TRUCKPULL
                            • 2971
                            #73
                            I got some test runs in yesterday.
                            Max speed on the Oval was 79 MPH.
                            Larry
                              • 9438
                              #74
                              Wow... smokin! 325.9 amps..... smokin!
                              • Bande1
                                • Mar 2023
                                • 678
                                #75
                                I missed it apparently what motor is that? is that on 5s?
