My Micro Hydro
  • JimClark
    • 5902
    #91
    Ok I think I will run one of these PolyRC Batteries either
    7.4V 1500mAh (2 cells) 25C/50C
    Rating: 25C (37.5A) continuous, 50C (75.0A) burst
    Dimension: 105mm x 32mm x 15mm
    Weight: 84 grams
    7.4V 2200mAh (2 cells) 25C/50C
    Rating: 25C (55.0A) continuous, 50C (110.0A) burst
    Dimension: 107mm x 32mm x 17mm
    Weight: 112 grams
    And think I am going to put the motor mount at 7 inches forward of the transom that places the motor at just slightly aft of the CG and gives me loads of room for batteries and esc in the nose. Going to make a small aluminum mount for it and reinforce the motor mount area with more glass and some plywood also. anyone got any good ideas for bullet connectors for the ESC to Motor> very tiny wires look very small in a 3.5mm Bullet.
    Jim
    Billy Graham
    • JimClark
      • 5902
      #92
      Motor, Strut and shaft locations Flex shaft is .098
      Billy Graham
      • Sneasle
        • 197
        #93
        What hardware is this?
        • JimClark
          • 5902
          #94
          It is the same strut you got from ebay. I only bought the strut and will use the solinger micro rudder
          Billy Graham
          • Sneasle
            • 197
            #95
            AH, ok. My shaft was drilled off center... so one of my drive line sets is unusable.
            • JimClark
              • 5902
              #96
              I am using a octura flex and one of their stub shaft
              Billy Graham
              • Sneasle
                • 197
                #97
                hmnm.. got part numbers for those?
                • JimClark
                  • 5902
                  #98
                  Steve has them
                  http://www.offshoreelectrics.com/pro...oct-oc098L-24c
                  Billy Graham
                  • JimClark
                    • 5902
                    #99
                    Anyone have any recommendation for paint for an abs hull? Preferably something that works with airbrushes.
                    Got my garage all set up for painting and am going to sit the micro aside now and paint the 1/16th scale Bardahl I have been working on.
                    Jim
                    Billy Graham
                    • Sneasle
                      • 197
                      #100
                      Good question, Something I've been trying to figure out as well.
                      I almost wonder if you could spray a rattle can into a container and then transfer that to the airbrush...
                      Airbrush paints are just so damn expensive..
                      • RandyatBBY
                        • 3915
                        #101
                        Hi Guys back from Az. House of color paint is what I use. They have little bottles all mixed for air brush for $11.00 to $18.00 a bottle.
                        Randy
                        BBY Racing
                        • Sneasle
                          • 197
                          #102
                          How little is 'little' and where can it be had?
                          • JimClark
                            • 5902
                            #103
                            Randy I only seem to find metalics and pearals no just solid colors. What other brand works well on aABS?
                            Jim
                            Billy Graham
                            • RandyatBBY
                              • 3915
                              #104
                              Jim
                              You can use Krylon or Fusion rattle Or any auto paint
                              Randy
                              BBY Racing
                              • RandyatBBY
                                • 3915
                                #105
                                they are 2 and 4 Oz. bottles they can be bought from any Auto body suply store.
                                Randy
                                BBY Racing
