My Micro Hydro
  • JimClark
    • 5913
    My Micro Hydro
    Ok I have now received one of Randy's micro dropped sponson hydros. I plan on reinforcing the interior with a combination of wood frames and fiberglass. Never having worked on a vacuum formed hull before I was wondering about what weight of fiberglass to get? Any ides on reinforcing would be appreciated as all I have done is scratch built wood or a carbon hull that was ready for finishing.
    Billy Graham
  • JimClark
    • 5913
    Here is my choice
    1975 Oberto
    Billy Graham
    • Dr. Jet
      • 1759
      Oh Lord, don't let Darin see that! Next thing you know there will be a fleet of Obertos!
      A nation of sheep breeds a government of wolves
      • RandyatBBY
        • 3944
        Originally posted by JimClark View Post
        Here is my choice
        1975 Oberto
        Thought I would give you a view that is about the same.
        Randy
        BBY Racing
        • RandyatBBY
          • 3944
          He just might want one
          Randy
          BBY Racing
          • Meniscus
            Refuse the box exists!
            • 3312
            Nice. Marketing at its best!
            • JimClark
              • 5913
              About the onlg thing I plan on changing is to modify the front of the cowl so it is 90 degrees instead of angled. Some of the drop sponson boats cowl were angled like Randy mad eit and a bunch were at 90 degrees like the Oberto is.
              I already contacted Darin to see what he has that i might be able to use in the way of templates so i can make the graphic files.
              going to use one of Dr Jets 3000kv brushless outrunner motor/esc $25.00 combo, a wire drive and one of Joe's micro rudders and a micro strut I got off of ebay
              a 2s lipo MAH to be determined and a X430r prop as I am going to be turning left like the real boats
              I also may try one of the little screamer brushless motors that has water cooling built in I have already talked to the designer about getting one
              Jim
              Billy Graham
              • JimClark
                • 5913
                another picrure of the real boat
                Billy Graham
                • Jesse J
                  scale FE enthusiast
                  • 7818
                  Beautiful! I bet that thing sounds like sweet thunder.
                  Ok, about that fiberglass, I am curious too - I have the turbine guy, but same question, weight and best resin.
                  "Look good doin' it"
                  See the fleet
                  • Sneasle
                    • 202
                    Well... that explains it.. I started my own thread about this hull, but everyone is in yours!!
                    I am going to build this one and one of the MH at the same time with the same hardware/motors/methods in an effort to give Randy a good solid comparison between the two hulls.
                    That being said, I'd be interested in seeing what you come up with for wood frames. I will use one of the Doc's for the MH, but I test fit them in the Shovel and there is no way they will fit without lots of cutting/sanding/modifying. If your frames work out well, I'd might want to use them here.
                    On the issue of glass, I have some 3.5-4oz glass I was planning on using, have some 1.5oz glass in the mail (maybe). Doc suggested using two layers of the lighter glasses, I'm not sure if it is actually needed though. The key to these hulls is keeping them light.
                    My motor choice as of now:
                    Anyone know of any other shovels I could paint mine after? Something unique that looks.. mean.. maybe?
                    • JimClark
                      • 5913
                      go to newtonmarine.com and look at page 10 and 11 for the drop sponson hulls
                      Jim
                      Billy Graham
                      • Sneasle
                        • 202
                        Thanks Jim.
                        I flipped through, not much jumped out at me.
                        Let me know how your wood frames progress. I may move my build into your thread at some point if you don't mind.
                        • JimClark
                          • 5913
                          The hard part is getting the top of the frames to fit. maybe Dr Jett has a trick up his sleeve on how to do that.
                          No problem on joining the thread
                          Jim
                          Billy Graham
                          • JimClark
                            • 5913
                            It might take me a little while. I just ordered some wood and fiberglass so I probably wont have anything for a week at least.
                            Jim
                            Billy Graham
                            • Sneasle
                              • 202
                              no worries, I'm a slow worker as well.
                              Anyone got any comments on that motor?
