Yes and no. I have found that they add a lot of torsional rigidity. Coupled with foam-filled (and bonded) sponsons, my MTH is stiff as a board. With such a small hull, you may get away with some strategically-placed carbon and fiberglass, but that lacks the "Coolness Factor" of the wood, and I don't know if it would be as stiff.
Does it need to be that stiff? I don't know for certain, but I would rather have a rigid hull than one that flexes, and "soaks up" power in so doing.
Years ago, I used to race track bikes (fixed-gear, velodrome bicycles), where sprinting is the name of the game. Stiffer is better in that arena. My custom-built track bike used a downtube from a tandem bike (WAY heavy-duty), ovaled front fork blades for chainstays (WAY heavy duty), steel handlebars and stem, cross-4 spokes that were tied and soldered. It was the stiffest thing I ever rode. You felt every bump on the track. You could throw it through a brick wall. BUT...all that stiffness translated into every ounce of power going into speed, not flexing some wimpy frame. That bike was an absolute rocket!
I would suspect the same would apply to a boat hull. My Campbell hydro is equally stiff and I am amazed at how well it handles; it's like nothing I have had before (H&M Viper, various vacuum-formed hydros).
I haven't, but I would be worried it would eat/melt more of the abs then you really wanted. I plan on sticking with the Gorilla glue for joining my halves, and then using the cab-o-sil/epoxy method for getting rid of the lip.
@ Doc
Thanks for the info, we do appreciate it. Have a look at my images if you have time. Where would you suggest additional framework?
I think Gorila glue makes a mess, Ok on lexan. I use nothing but Thick, thin and med CA with kicker. I have not ran one of these boats with any FG or wood frame work. I just run a transom and turn fin doubbler (wood). With the power we have the stiffness will not hurt anything and the extra weight does helps. I just use lead for more weight.
Randy
For ABS, Fiberglass, Carbon hulls and Stainless hardware BBY Racing
@ Doc
Billy Graham
The cab-o-sil and epoxy method is what Doc used in his MTH thread (the original SSSH thread I think) to get rid of the lip on his version 2 boat. The cab-o-sil is a filler of some sort.
Basically, you mix the stuff up and smear it into the lip after the halves are glued together. I think it should be thin enough to work it's way in, and then you go in and sand it down to bring that lip in line with the hull and make it nice and smooth. It will take several applications and lots of elbow grease, but that is how Doc got his hull as nice looking as it is.
Ok I think I have brainstormed enough on this one and have a plan. I am going to make several frames for it and want a wide stringer to support the top (see picture below). I also would like to add balsa on the outside edges of the bottom to give a good glue surface for the top then I can hopefully sand off the top flange flush for a cleaner looking hull. I may put a light fiberglass over the edge also.
Jim
Billy Graham
I notice that neither the hull edge or the deck edge is cut straight. What should I do to the hull to ensure that I get a good, even, twist free hull when I go to glue them together?
If I had a really big belt sander I would smooth the hull on that, but I don't.
I'm going to cut the template at the joint with the forward bulkhead. That ok with you?
Just as a note, if you look at my images, you'll notice the stringers are taller then the bulkhead. That is because the stringer fit into a raised groove in the deck, while the bulkhead goes all the way across the hull and I didn't feel like doing the fancy cutting required to make it match up perfectly.
Reason: added info and a question
Jim, here is the outline for the formers. Let me know if you have any issues. There is a scale drawn to help you, you will probably have to rescale it to print it correctly.
