Slow build - 8S Twin Cat
    Can you remember the approximate distance of the motor mounts in your old Mean Machine? It would help give me an idea for my little twin.
    • TRUCKPULL
      • 3293
      #77
      Ray here are some pictures, I hope these help.
      Larry
        Thank you, helps a lot. I will mount mine closer to transom.
          Did you lay it out for the CG before you committed to that spot or did you just choose a place?
          • TRUCKPULL
            • 3293
            #80
            RAY - I did lay it out according to the CG.
            Larry
              Thanks again!
              • TRUCKPULL
                • 3293
                #82
                I was working on a couple of Swordfish X+ 200A ESC's today.
                The water inlets were only .095" inside, So I took some measurements
                To see if a piece of 5/32" brass tubing would make it better.
                It will fit.
                So I drilled out the ESC to 5/32" all the way through, then I used a 3/16" reamer to open up the ends to 7/16" deep.
                Every thing would fit like a charm.
                This would make the water flow 2.8 times more then before.
                I then had to come up with a way to make the tubing secure so it would not just slid off.
                Even with a wire tie. I still needed a bump on the end to stop it from sliding.
                Larry
                • TRUCKPULL
                  • 3293
                  #83
                  So I cut a few pieces of 5/32" tubing 1" long, heated one end up and quenched it in water to soften it.
                  I took a piece of 3/16" Dia. aluminum . turned the end down to 5/32" to fit into the tubing with a taper at the top.
                  I then put this piece into the tube, and used a small tap hammer about 4 to 5 taps, to flare out the end.
                  I then heated the end up again and let it Air cool to harder it.
                  A little JB weld to hold the tubes in place.
                  Now we have good water flow and no change of a water line coming off.
                  I think that you could also use a flare kit for 3/16" brake line.
                  Larry
                    Nice work Larry. Always seems to be room for improvement
                    • TRUCKPULL
                      • 3293
                      #85
                      Thank You Shawn
                      Larry
                      • TRUCKPULL
                        • 3293
                        #86
                        Things have kind of come to a halt right now.
                        I had to send one of my ESC's back to Offshore for a replacement.
                        Water leak from one of the brass tubes.
                        Second picture is as they come from Offshore.
                        At first I only trimmed the Black heat shrink enough to put the tubing on the brass tube. (see third picture)
                        The leak was still under the black heat shrink.
                        I did not find it untill I cut off the black heat shrink all the way back to the ESC.
                        Larry
                        • TRUCKPULL
                          • 3293
                          #87
                          A Little pit of progress, seeing that I am waiting for my ESC to return from Swordfish, And have other boats to clean up and get ready for the race season. I have sent this hull out for a wicked paint job. I will show some pictures as the process continues.
                          Larry
                          • Shooter
                            Team Mojo
                            • Jun 2009
                            • 2751
                            #88
                            Can't wait to see this thing Larry. Nice cooling improvements.
                            • TRUCKPULL
                              • 3293
                              #89
                              Sneak peak at the paint job for this beast.
                              This is only the striping. More to come yet.
                              Larry
                                Looking FINE! Larry.
