Slow build - 8S Twin Cat
  • TRUCKPULL
    • 3293
    I bought this hull 3 years ago from a friend in Florida
    With Coivd it took me almost 3 years to get it home.
    It is a Carbon Kevlar hull, after I cut out the plywood rails,
    the hull felt a little flimsy, so I put a Carbon Fiber liner in it.
    The drives were bought here on the forum, I did modify them
    so the drive tube would come all the way through,
    so I could use the Speedmaster stinger bushings (Product IDros-spdsd-250)
    I bought a 40 -60 rudder from Sly Cat Racing It has water inlets on both sides of the blade,
    NO shortage of flow on this one. I combined this with a Speedmaster Duel push pull pivot block,
    and a 6" long Mount.
  • Panther6834
    • Apr 2020
    • 708
    Looks great. Sometimes, 'slow & careful' is better than "gotta get this done asap".
    ~ More peace, love, laughter, & kindness would make the world a MUCH better place
    • TRUCKPULL
      • 3293
      Thank You Robb.
      Larry
      • Jesse J
        scale FE enthusiast
        • 7818
        Larry,
        What hull is this? Can you post a side shot?
        Thanks,
        Jesse
        "Look good doin' it"
        See the fleet
        • TRUCKPULL
          • 3293
          Falcon Cat - made in Vietnam.
          Larry
          • Jesse J
            scale FE enthusiast
            • 7818
            Nice, how long/wide?
            See the fleet
            • TRUCKPULL
              • 3293
              42" Long X 16" Wide
              Larry
              • TRUCKPULL
                • 3293
                Can anyone guess what this will be used for?
                I turned it up on my lath out of a piece of 1 1/2" Dia. aluminum
                I wanted the small Dia. at 0.281 (9/32"), I whent a little under size, so I turned it down to 0.250 (1/4") and used some CA to put a piece of 9/32" tubbing on it.
                Larry
                • jaike5
                  • 564
                  Is it a paddle shifter stem for a man bidet ??
                  • 1coopgt
                    • Feb 2019
                    • 417
                    Larry
                    I'll play. An antenna tube feedthru.
                    • TRUCKPULL
                      • 3293
                      Second clue!
                      It is something to do with a TP -5670 Motor
                      • BlakeT
                        • Jan 2020
                        • 536
                        I’ve always liked those falcon cats wish I could get my hands on one. That build is looking very nice! Hope to see some videos once it is done
                        • Jesse J
                          scale FE enthusiast
                          • 7818
                          That will be used to align the motor shaft and flex cable.
                          See the fleet
                          • TRUCKPULL
                            • 3293
                            Winner Winter - Chicken Dinner.
                            Larry
                            • TRUCKPULL
                              • 3293
                              From the cardboard cut outs for the motor mounts, I made the motor mounts out of two pieces of 2mm carbon fiber
                              epoxied together for each one.
                              I then machined the center clearance hole the same size as the first step on the alignment tool.
                              Seeing that I wanted to use Three X 4mm mounting holes. I positioned the top hole 15mm from the center hole.
                              Then two more holes 120 degrees apart each.
                              Larry
